Geocode Service from my custom Map Services
1696
03-27-2014 03:27 AM
Vibin_DhasDevadhason
Could i have an clear idea about using the Geocode for my custom mapservices.  How to integrate whether it is possible or not..
TimWitt
Hi there,
this sample should help you.
Where it says
var locatorUrl = "http://servicesbeta.esri.com/ArcGIS/rest/services/LocateValveByAssetID/GeocodeServer";
just put the URL to your service and it should work.
Tim
Hi there,
Where it says
Tim
For creating the Custom Geocode service i have used the following resource..
http://resources.arcgis.com/en/help/main/10.1/index.html#/Exercise_1_Creating_an_address_locator/002...
TimWitt
You would need to have Arc Server to be able to use it in your application. See here.
Off-course i did published using Arc Server.
Thanks..
