GeoCode locator not working properly for POI or Business
1651
06-19-2017 05:52 PM
arunepuri1
Hi All,
We are using ArcGIS Javascript API V 3.4 with "esri/tasks/locator", "esri/tasks/AddressCandidate",
When searched with Business names(Startbuck, San Francico or Walmart San Ramon) the suggestion are coming properly with magickey and bound the dataset to Grid
But when selected a row in the data grid, for user required address. The address locator not giving proper lat, longs.
GeoCode locator URL: http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer
Javascrpt Code snippet.
//Passing the one the suggestion address to get the lat,long
var newaddress = {
singleLine: item.address,
magicKey: item.Magickey
esrilocator.outSpatialReference = map.spatialReference;
esrilocator.addressToLocations(newaddress);
esrilocator.on("address-to-locations-complete", function (e) {
//Zoonto result lat,long
Checked direct URL which ESRI using  http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer/findAddressCandidates?SingleLine=...
This also not working properly.
Anyonce faced the similar issue with esrilocator.addressToLocations
Please let me know your thoughts and suggestions
arunepuri1
The issue fixed
the reason was passing the parameters in proper order/Passing address as object
//Error code
var newaddress = {
l.
//Working code
var address = { "singleLine": item.address };
var newaddress = { address: address, magicKey: item.Magickey };
