format output of suggestionTemplate for Search dijit
3524
12-15-2015 07:38 PM
PatKeegan
My suggestion template for a search digit produces typical simple output, example:
suggestionTemplate: "${BILLNAME}  -  ${PIN}"
I'd like add a return between two values, such as:
suggestionTemplate: "${BILLNAME} </br>  ${PIN}"
Is there a way to embed a line break (or other goodness)?
I played around suggestion template sandbox, but could not figure a way
ArcGIS API for JavaScript Sandbox
thanks
RobertScheitlin__GISP
Pat,
  It can be done with some css and \n in the template:
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Search with Suggestion Template</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
  <style>
    html,
    body,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #search {
      display: block;
      position: absolute;
      z-index: 2;
      top: 20px;
      left: 74px;
    .searchMenu.suggestionsMenu>div>ul>li {
      display: block;
      white-space:pre;
  </style>
    <script src="https://js.arcgis.com/3.15/"></script>
  <script>
    require([
        "esri/map", "esri/dijit/Search", "esri/layers/FeatureLayer",  "esri/InfoTemplate", "dojo/domReady!"
      ], function (Map, Search, FeatureLayer,InfoTemplate) {
      var map = new Map("map", {
        basemap: "gray",
        center: [-82.93, 42.5], // lon, lat
        zoom: 10
      var search = new Search({
        sources: [{
          featureLayer: new FeatureLayer("http://services.arcgis.com/b6gLrKHqgkQb393u/arcgis/rest/services/TaxParcelQuery/FeatureServer/0", {
            outFields: ["*"],
            infoTemplate: new InfoTemplate("Parcels", "Owner name: ${OWNERNME1}</br>Parcel ID: ${PARCELID}</br>Site address: ${SITEADDRESS}")
          outFields: ["OWNERNME1","PARCELID","SITEADDRESS"],
          displayField: "OWNERNME1",
          suggestionTemplate: "${PARCELID}: \n${SITEADDRESS}",
          placeholder: "example: Shawn Smith",
          enableSuggestions: true
        map: map
      }, "search");
      search.startup();
  </script>
</head>
<body>
  <div id="search"></div>
  <div id="map"></div>
</body>
</html>
Pat,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #search {
      display: block;
      position: absolute;
      z-index: 2;
      top: 20px;
      left: 74px;
      display: block;
      white-space:pre;
  </style>
  <script>
    require([
        basemap: "gray",
        zoom: 10
        sources: [{
            outFields: ["*"],
        map: map
      }, "search");
      search.startup();
  </script>
</head>
<body>
</body>
</html>
PatKeegan
Works perfectly!  thanks
