Format infoTemplate content with custom function
6507
11
09-24-2013 09:27 AM
RyanClancy
I'm trying to format the value of a field for display in an infoTemplate but nothing is happening; it appears as though the function is not being called. I used the example here as a guide, see the compare() function.
I simply want to format the text to display either Gbps or Tbps based on the value of the field. The relevant field is called "Capacity_G" and I put the console.log statements in there to test whether the function was executing; it is not.
var infoTemplate = new InfoTemplat(); infoTemplate.setTitle("<b>Cable: ${NAME}</b>"); infoTemplate.setContent("Capacity: ${CAPACITY_G:formatCapacity}");  function formatCapacity(value){     console.log("LALALALALAA");     var cap = "";     //1Tb = 1024Gb     if (value >= 1024){         cap = value/1024 + "Tbps";     }     else {         cap = value + "Mbps";     }     console.log("LALALALALALALA");     return cap; }
What have I done wrong? The text in the resulting popup appears unmodified, exactly as it is in the attributes of the data.
DominickCisson
Are you using 3.7? graphic.attr() was introduced at 3.7 (we'll update the docs to say this).
Attr is also used to add attributes to a graphic's DOM node, it doesn't affect graphic.attributes (which I admit is confusing). If you want to add to or update a graphic.attributes, modify that object directly.
Do you know of an example of how to add a real attribute to a graphic?  and I'll second the original poster here, graphic.attr is very confusing.  What exactly is the point of adding an attribute to a graphic's DOM node?
DominickCisson
Never mind... Figured it out.  It's JSON 101 Duh.
Just set the attribute directly... graphic.attribute.<attribute name> = "New value"
