Floating Panels
1327
05-21-2014 08:59 AM
deleted-user-yA_w_FC9FKe5
I am trying to create floating panels in Javascript for the Measurement widget.  I think my problem is pretty simple for someone smarter than I am.  My problem lies in that when I click on the map using this tool the place where I click is way off from where the flag shows up on the map.  I think it has to do with the titlepane but I need to keep that.  This is just a simple example but what I am doing is using the title pane as a filter and then bringing in the measument tool via a button and floating panel.  The problem is the same and I believe it is because of the title pan.  If you click on the tool and create to points you will see they are way off.  then if you downsize the title pane and then click again you will see they are closer together but still off.
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
    on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>
      Measure Tool
    </title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/2.5/js/dojo/dijit/themes/claro/claro.css">
    <style type="text/css">
      html,body {
        height:100%;
        width:100%;
        margin:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
      #map {
        border:solid 2px #808775;
        -moz-border-radius:4px;
        -webkit-border-radius:4px;
        border-radius:4px;
        margin:5px;
        padding:0px;
      #titlePane{
        width:240px;
      .claro .dijitTitlePaneTitle {
        background: #808775;
        font-weight:600;
        border:solid 1px #29201A;
      .claro .dijitTitlePaneTitleHover {
        background:#808775;
      .claro .dijitTitlePaneTitleActive {
        background:#808775;
      .claro .dijitTitlePaneContentOuter {
        border-right: solid 2px #808775 !important;
        border-bottom: solid 2px #808775 !important;
        border-left: solid 2px #808775 !important;
      </style>
      <script type="text/javascript">
        djConfig = {
          parseOnLoad:true
      </script>
      <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=2.5"></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.TitlePane");
      dojo.require("dijit.form.CheckBox");
      dojo.require("esri.map");
      dojo.require("esri.dijit.Measurement");
      dojo.require("esri.SnappingManager");
      dojo.require("esri.dijit.Scalebar");
      dojo.require("esri.layers.FeatureLayer");
      var map;
      var measurement;
      function init() {
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications
        esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
       var initialExtent = new esri.geometry.Extent({"xmin":-9545482,"ymin":4615382,"xmax":-9544248,"ymax":4616059,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map", {
          extent:initialExtent
        dojo.connect(map, 'onLoad', function(map) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/arcgis/rest/services/World_Street_Map/MapServer");
        map.addLayer(basemap);
        var sfs = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID,
         new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,
         new dojo.Color([195,176,23]), 2),null);
        var parcelsLayer = new esri.layers.FeatureLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Louisville/LOJIC_LandRecords_Louisville/MapServer/0", {
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"]
        parcelsLayer.setRenderer(new esri.renderer.SimpleRenderer(sfs));
        dojo.connect(map, "onLayersAddResult", function(results){
          //dojo.keys.copyKey maps to CTRL on windows and Cmd on Mac.
          var snapManager = map.enableSnapping({snapKey:dojo.keys.copyKey});
          var layerInfos = [{layer: parcelsLayer}];
          snapManager.setLayerInfos(layerInfos);
          createMeasure();
        map.addLayers([parcelsLayer]);
      //show map on load
      dojo.addOnLoad(init);
     function createMeasure(){
        measurement = new esri.dijit.Measurement({
          map: map
        }, dojo.create('measure'));
        dojo.place(measurement.domNode,dojo.byId('measurementDiv'));
       measurement.startup();
       measurement.setTool("distance", true);
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline',gutters:'false'"
    style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'center'">
       <button id="tglMeasurementOff" type="button" onclick="tglMeasurementOff();">toogleMeasurementOff</button>
      <button id="tglMeasurementOn" type="button" onclick="tglMeasurementOn();">toogleMeasurementOn</button>
          <div id="titlePane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'">
            <div id="measurementDiv"></div>
            <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span>
          </div>
      </div>
    </div>
  </body>
</html>
