Flashing Flow Renderer after version 5.0
1295
03-03-2026 02:06 AM
JonathanDawe_BAS
I recently did an experiment with flow renderers from a COG imagery tile. I see that in version 5.0 of the ArcGIS API there are new improvements to the behaviour of the renderer on moving the map.
Unfortunately on changing to version 5.0 I'm now seeing strange flashing of vector flow symbology on "no data" parts of my COG.
Before (4.34): https://codepen.io/Jonathan-Dawe/pen/XJKGmmg
After (5.0):  https://codepen.io/Jonathan-Dawe/pen/YPGymvw
Is this a bug with the renderer, or an issue with my underlying data?
AnneFitz
Hi @JonathanDawe_BAS - this seems like a bug. We'll investigate. Thank you for letting us know!
JonathanDawe_BAS
A workaround I have at the moment is to add some kind of opacity visual variable...
    field: "Raster.Magnitude",
      stops: [
        { value: 0,   opacity: 1 },
        { value: 100,   opacity: 1 },
        { value: 100.1, opacity: 0 },   // anything above this → fully transparent
        { value: 9999, opacity: 0 },
AnneFitz
AnneFitz
@JonathanDawe_BAS this issue was fixed in today's patch, 5.0.10! Let us know if you are still running into any issues.
