First attempt at using a geoprocessing service in a js web app
7304
11
02-25-2015 09:42 AM
ChrisRomsos
I'm a novice web developer and have run into a snag and am not sure how to proceed.
Objective:  create a simple web viewer using the javascript API for arc gis server.  Create a button in the application that triggers an asynchronous geoprocessing service and adds the output as a dynamic map layer.
Progress: Using the example code on the ESRI webpages I quickly re-deployed the basic js example of a web app that loads a dynamic map service.  Next, I read the online help related to using a geoprocessing service in a web app and displaying the results here.
ArcGIS Help 10.1 ‌"using"
and here
ArcGIS Help 10.1  "displaying"
Note: the geoprocessing service works when I test it from arcmap etc.
I'm not sure if I should post code directly to this message or not, so instead I'll put a link to the site.  Then view source should reveal the code.
Link to non functional app
Thanks, Chris
TimWitt2
Chris,
the following code will run on button click:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Create Map and add a dynamic layer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css"/>
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; }
      .shadow {
        -moz-box-shadow: 0 0 5px #888;
        -webkit-box-shadow: 0 0 5px #888;
      #mapDiv{ margin: 0; padding: 0; }
      #leftPanel {
        margin:5px;
        background: #fff;
        color: #444;
        font-family: arial;
        width: 250px;
        border-right: solid 1px #888;
      #footer{
        border-top: solid 1px #888;
        height:55px;
      #status{
        background-color:#E0E0E0;
        color: #707070;
        font-weight:bold;
        padding: 3px;
        border: solid 1px #707070;
        -moz-border-radius: 5px;
        -webkit-border-radius: 5px;
        border-radius:5px;
        position:absolute;
        top:50%;
        right:50%;
        z-index:100;
        display:none;
        height:20px;
    </style>
    <script src="http://js.arcgis.com/3.12/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/layers/ArcGISDynamicMapServiceLayer",
        "esri/layers/ImageParameters",
  "esri/dijit/BasemapToggle",
  "dojo/on",
  "dojo/parser",
  "dijit/registry",
  "esri/tasks/Geoprocessor",
  "dojo/dom",
  "dijit/layout/BorderContainer",
  "dijit/form/Button",
        "dojo/domReady!"
      ], function (
        Map, ArcGISDynamicMapServiceLayer, ImageParameters, BasemapToggle,on, parser,registry, Geoprocessor, dom) {
        //parser.parse();
  map = new Map("mapDiv", {
          basemap: "topo",
          center: [-124.5, 44.15],
          zoom: 8
  var toggle = new BasemapToggle({
          map: map,
          basemap: "satellite"
        }, "BasemapToggle");
        toggle.startup();
////////////////////////  Geoprocessing
  // esri.tasks.gp is required for using Geoprocessor.
  //  Add it along with other dojo.require statements.
  /* Step 1: Initialize Geoprocessing Task as a global variable.
  That is, declare the variable outside a function definition
  since we will be using gpTask variable in other methods */
  var gpTaskUrl="http://bhc.coas.oregonstate.edu:6080/arcgis/rest/services/geoprocessing/RasterPlusModel/GPServer/Mod...";
  var gpTask = new Geoprocessor(gpTaskUrl);
  // Set output spatial reference property to map's spatial reference.
  //   myMap is assumed to be an instance of map container esri.map.
  gpTask.outSpatialReference=map.spatialReference;
  //Step 2: Setup Parameters of the task
  function setupParameters(){
  // Get Input Parameter 1 : GPFeatureRecordSetLayer from fLayer.
    var Input_raster_or_constant_value_1 = "Cetaceans\\Initial\\suitability";
    // Get Input Parameter 2 : GPLinearunit from a dojo UI element
    var Input_raster_or_constant_value_2 = "Cetaceans\\Initial\\suitability";
    var params= {"Input_raster_or_constant_value_1":Input_raster_or_constant_value_1, "Input_raster_or_constant_value_2":Input_raster_or_constant_value_2};
    // Return name-value pairs of parameters
    return params;
  on(dom.byId("hotspotButton"), "click", myGPSubmitJob);
  //Step 3: Run the task
  function myGPSubmitJob(){
  // Get params from setupParameters method described above.
  var params=setupParameters();
  // Setup event handlers.
  dojo.connect(gpTask, "onJobComplete",onTaskComplete);
  dojo.connect(gpTask, "onError",onTaskFailure);
  dojo.connect(gpTask, "onStatusUpdate",onTaskStatus);
  gpTask.submitJob(params);
  // On Job Complete Callback add a dynamic map service using ResultMapService
  function onTaskComplete(jobInfo){
  //replace mapservice url with your url and append jobid
  var mapurl = "http://bhc.coas.oregonstate.edu:6080/arcgis/rest/services/geoprocessing/RasterPlusModel/MapServer/jo..." + jobinfo.jobId;
  //create a dynamic map service
  var gpResultLayer = new esri.layers.ArcGISDynamicMapServiceLayer(mapurl, {
  opacity: 0.5
  //add to web application.
  map.addLayer(gpResultLayer);
  // Event handler for onStatusUpdate event
  function onTaskStatus(jobInfo) {
  //write status to console to help debugging
  console.log(jobInfo.jobStatus);
  // Event handler for onError event
  function onTaskFailure(error) {
   // Report error
   alert("Error:"+ error);
   app = {
        myGPSubmitJob: myGPSubmitJob
    </script>
  </head>
  <body>
  <div data-dojo-type="dijit.layout.BorderContainer"
       data-dojo-props="design:'headline',gutters:false"
       style="width: 100%; height: 100%; margin: 0;">
    <div id="mapDiv"></div>
  <div id="leftPanel" data-dojo-type="dijit.layout.ContentPane"data-dojo-props="region:'left'">
        <div align="center">
   <button id="hotspotButton" data-dojo-type="dijit.form.Button" type="button" data-dojo-attach-point="button">Submit Job</button>
        </div>
    </div>
  </div>
  </body>
</html>
Hope this helps!
Tim
ChrisRomsos
Oops, itchy trigger finger.  I should have added that the PROBLEM I'm having is that I don't really understand how to have the button run the geoprocessing task and return the result.  I suspect I've either messed that up or improperly specified the inputs to the geoprocessing task.
Thanks
TimWitt2
Chris,
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      .shadow {
      #leftPanel {
        margin:5px;
        background: #fff;
        color: #444;
        font-family: arial;
        width: 250px;
      #footer{
        height:55px;
      #status{
        color: #707070;
        font-weight:bold;
        padding: 3px;
        border-radius:5px;
        position:absolute;
        top:50%;
        right:50%;
        z-index:100;
        display:none;
        height:20px;
    </style>
    <script>
      var map;
      require([
        "esri/map",
  "dojo/on",
  "dojo/parser",
  "dijit/registry",
  "dojo/dom",
        "dojo/domReady!"
      ], function (
        //parser.parse();
          basemap: "topo",
          zoom: 8
          map: map,
        toggle.startup();
    return params;
  opacity: 0.5
   // Report error
   app = {
    </script>
  </head>
  <body>
        </div>
    </div>
  </div>
  </body>
</html>
Hope this helps!
Tim
ChrisRomsos
I'll give it a try.  thanks Tim.
-Chris
TerryGustafson
Hey Chris,
I was trying to do something similar.  Did you have any luck with this?
Terry
TerryGustafson
Tim, this sounds like what I would like to do..  Did Chris ever say whether it worked for him?
TimWitt2
I don't know, but it is always a good sign when no answer follows
TerryGustafson
That is a good point. ☺ So would that code you showed him go in the widget.js file?
TimWitt2
Yes inside the widget.js is where you have all your functions.
TerryGustafson
Then I would have to create the widget.html and the config.json file? What is the manifest.json file for?
