FireFox - stylesheet and map display
1006
02-21-2014 04:11 AM
ShaningYu
Honored Contributor
In one page in my web project, the map displays well on IE but not does not on Firefox.  The MS VS warning message is below:
Unable to edit 'http://js.arcgis.com/3.8/js/esri/css/esri.css'.  The stylesheet must be part of the current project and the project must be a Web Site or Web Application.
I use VS 2010.  I tried to load the css locally rather than through internet, but the warning is still the same.  How can this problem be solved?  Thanks in advance if you can share your experience.
