Firebug error : dojo.io.script error
6036
7
03-19-2014 10:38 AM
YvanBérard
Hello guys,
first, thanks for helping.
Here is my problem. In firebug, with the JS API 3.8 I've started receiving some weird error...but my script is still working.
How can I make these errors disappear
Here are the errors from Firebug:
dojo.io.script error     /3.8/ (line 1416)
Error
.cache["esri/request"]/</s/e.load()/3.8/ (ligne 784)
.cache["dojo/_base/xhr"]/</b._ioSetArgs/<()/3.8/ (ligne 186)
c()/3.8/ (ligne 74)
d()/3.8/ (ligne 74)
.cache["dojo/_base/Deferred"]/</b.Deferred/this.callback()/3.8/ (ligne 75)
c()/3.8/ (ligne 74)
d()/3.8/ (ligne 74)
.cache["dojo/io/script"]/</c.get/<()/3.8/ (ligne 1414)
.cache["dojo/Deferred"]/</f()/3.8/ (ligne 194)
.cache["dojo/Deferred"]/</q()/3.8/ (ligne 194)
.cache["dojo/Deferred"]/</e/this.resolve()/3.8/ (ligne 196)
.cache["dojo/Deferred"]/</a()/3.8/ (ligne 195)
.cache["dojo/Deferred"]/</f()/3.8/ (ligne 195)
u()/3.8/ (ligne 1044)
.cache["dojo/request/script"]/</n/w[g.id]()/3.8/ (ligne 1045)
.cache["dojo/io/script"]/</c._jsonpCallback()/3.8/ (ligne 1418)
()MapSer...allback (ligne 1)
Reload the page to get source for: http://js.arcgis.com/3.8/
JeffPace
without seeing code its going to be nearly impossible to help, but it looks like maybe you have a callback that has incorrect parameters
YvanBérard
with some debugging, I've managed to find where the error occur
layer = new esri.layers.ArcGISDynamicMapServiceLayer(url+"/MapServer", {id:oParamUser.config.layer, imageParameters: imgParams});
This line seems fine....I don't know what's wrong...
JeffPace
make sure your requires are correct, and make sure {id:oParamUser.config.layer, imageParameters: imgParams}
oParamUser.config.layer and imgParams are not null
and that imgParams is a valid esri/layers/ImageParameters object
YvanBérard
and i'm using the Legacy Module Require and it doesn't seem to need a specific "require" except the dojo.require("esri.map");
YvanBérard
imgParams is declared and modified this way:
var imgParams = new esri.layers.ImageParameters();
imgParams.format = "png32";
oParamUser.config.layer contain an id like "this_is_my_layer"
JeffPace
it might be my lack of sleep, but you still need
dojo.require("esri.layers.ArcGISDynamicMapServiceLayer")
dojo.require("esri.layers.ImageParameters");
etc..
YvanBérard
These are all the require declaration I use:
Note taht the esri.layers.agsdynamic and agstiled are the new "way" to call them in 3.8 with the Legacy Module
 dojo.require("esri.layers.agsdynamic");
 dojo.require("esri.layers.agstiled");
 dojo.require("esri.dijit.Scalebar");
 dojo.require("esri.dijit.Print");
 dojo.require("esri.dijit.Measurement");
 dojo.require("esri.dijit.Legend");
 dojo.require("esri.dijit.OverviewMap");
 dojo.require("esri.toolbars.navigation");
 dojo.require("esri.toolbars.draw");
 dojo.require("esri.tasks.query");
 dojo.require("esri.tasks.find");
 dojo.require("esri.layers.osm");
