FindTask Live Search
2091
6
01-17-2012 04:18 AM
Salomon_VágadalJoensen
How do I implement a Live Search functionality into this http://help.arcgis.com/en/webapi/javascript/arcgis/demos/find/find_map_datagrid.html sample?
I've looked around the Web a bit, and I'm at loss where to start.
derekswingley1
What is "Live Search"?
With Live Search, I mean a search box that returns an updated search result in a drop-down box for every key-press. Think Google's suggestion box returned from the user's typing. IDK if this is clear enough.
Well, I've worked out how to do it, but it still needs more work.
I've used Query to do it, to get query results from the server. I got most of the functionality and setup from this sample:
http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/query_nomap.html
Where I use esri.tasks.Query to query the MapServer for results
  function queryResults(results) {
   queryHaldari = queryFilter(results);
   console.log(queryHaldari);
   s = "";
   for (var i=0, il=queryHaldari.length; i<il; i++) {
    s = s + "<div><b>Veganavn:</b> " + queryHaldari[0].attributes.veganavn + ", <b>Bygd:</b> " + queryHaldari[0].attributes.bygd_1 + "<br /></div>";
   dojo.byId("searchList").innerHTML = s;
  function queryResults2(results) {
This is the main component, nevermind the other function calls.
Now I'm trying to get more functionality to s and give it like onmouseover and onmouseout and onclick, but I'm uncertain on how to add that programmatically.
Marie-GilSeptfonds
Hello,
In the past I've tried to implement an autocomplete (live search ?) for searching an adress which is updated at any key pressed.
I didn't find a solution with a Mapservice.
The only one solution I've found, is to use a PHP wich sends a request to my Database (Oracle) and return the response in a json format.
This Json is formatted for a dojox.data.QueryReadStore which is conected dijit.form.FilteringSelect.
[ATTACH=CONFIG]11321[/ATTACH]
Nice, that is somewhat I want it to look like; now I send the results to a div that I format programmatically and it's quite ugly compared to your method.
This is how it looks now, I'm pretty happy with how it turned out, I just need to do some CSS and add onclick, onfocus and make it able to scroll between autocomplete (live search) results.
