Finding Intersection of two polygons in popup
2404
09-23-2021 02:36 PM
JeffreyThompson1
I am attempting to calculate the area of intersection for two feature layers in a popup field. The layer I am building the popup for is called Parcels and the other layer is Impact Area. This is my best guess at the expression, but it is returning blank.
expression: "AreaGeodetic(Intersection($feature, FeatureSetByName($map, 'Impact Area')), 'acres')"
Any suggestions?
JeffreyThompson1
I came up with a solution. (For a single impact area shapefile)
expression: "AreaGeodetic(Intersection($feature, First(FeatureSetByName($map, 'Impact Area', ['*'], true))), 'acres')"
I found out I also need to handle multiple impact area shapefiles and corrected a couple errors in the original reply to get my final solution.
var impact_areas = Intersects($feature, FeatureSetByName($map, 'Impact Area', ['*'], true))
var impacted_area = 0
for(var ia in impact_areas) {
    impacted_area += AreaGeodetic(Intersection($feature, ia), 'acres')
return impacted_area
Thanks @JohannesLindner  I wouldn't have got there without you.
JohannesLindner
Intersection takes 2 geometries as input, you use a feature set as second argument.
Assuming that a parcel can intersect multiple impact areas and that impact areas do not overlap:
var impact_areas = Intersects($feature, FeatureSetByName($map, 'Impact Area'))
Have a great day!
Johannes
JeffreyThompson1
@JohannesLindner
To clarify, I have one impact area on my map which intersects with multiple parcels that do not overlap with each other. I am looking for the area in a single parcel that falls within the impact area. Based on your suggestion I have tried the following code. It also returns blank with this error: SyntaxError: Unexpected token o in JSON at position 1
expression: "AreaGeodetic(Intersection($feature, Geometry(FeatureSetByName($map, 'Impact Area', ['*'], true))), 'acres')"
I also attempted your solution and it also returned blank with a Missing Parameters error.
What is the best way to select the geometry from another map layer to use in this function?
JohannesLindner
Ah yes, I missed the $feature in the Intersects function. Should have tested it, sorry.
I edited my original reply for future reference.
Have a great day!
Johannes
JeffreyThompson1
