Find task with wildcards?
1727
5
08-12-2014 04:16 AM
AdrianMarsden
Honored Contributor
Hi
I'm trying to re-create this T-SQL in a find task
SELECT     OBJECTID, UPRN, LADDRESS, PASTEADDRESS, LOGICAL_STATUS, LPIKEY, PROPERTY_TYPE, ORGANISATION, USRN, STREET_NAME, TOWN_NAME, LOCALITY,
                      POSTCODE, POSTTOWN, UPDATED, STREET_REF_TYPE, POSTALLYADDRESSABLE, PROPERTYSTATE, LPISTATUS, XREF, YREF, Shape, SortPAON
FROM         v_ADDRESSES_FULL_LLPG
WHERE     (PASTEADDRESS LIKE N'1 %FORE STREET%')
The important bit is the WHERE.
This will return "1 Fore Street" but also " 1 The Fishermans,  Fore Street" , "1 - 4 Forestreet" and a host of others.
How do I specify this in a query for a find task?
Cheers
ACM
This
RobertScheitlin__GISP
Adrian,
  The FindTask does not allow for a where clause as it uses a searchText property that defines the where clause internally. You can have the QueryTask use your where clause specified above. One thing that sticks out to be is the PASTEADDRESS LIKE N'1 %FORE STREET%' I have not seen the "N" used in SQL before is this a typo or does it actually do something in TSQL?
AdrianMarsden
Honored Contributor
The N - Dunno - it is what SQL Manager puts in when you design a query - I have no idea why or what it does - I never write it myself and they always work
AdrianMarsden
Honored Contributor
Ah
sql server - What is the meaning of the prefix N in T-SQL statements? - Stack Overflow
You may have seen Transact-SQL code that passes strings around using an N prefix. This denotes that the subsequent string is in Unicode (the N actually stands for National language character set). Which means that you are passing an NCHAR, NVARCHAR or NTEXT value, as opposed to CHAR, VARCHAR or TEXT.
Adrian,
   Good to know. So have you tried the queryTask using that where clause?
AdrianMarsden
Honored Contributor
Not yet - it would take a fair bit of re-coding - not that urgent at the moment - thanks anyway.
