Find min and max values of a field (column) in a feature layer
1744
05-11-2022 10:04 AM
Maxycle
I am using ArcGIS API for Javascript in a Nuxt application and I would like to find the max and min values of a field in a feature layer hosted on ArcGIS. How to do that ?? The values for the stops for the visualVariables are hard coded and I would like them to be dynamic and take the min and max values of the field.
ReneRubalcava
Esri Frequent Contributor
You can use StatisticDefinition with the query.outStatistics to get the min/max values.
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-support-StatisticDefinition....
You can search for "statistics" in the Sample Code page and find a number of samples including this one.
https://developers.arcgis.com/javascript/latest/sample-code/popup-customcontent/
