Hello all,
I am adding a CSV layer to my JS map. Is it possible to filter the layer by attribute values using the JS API?
I have tried using the "setDefinitionExpression" method but it seems to only work with Esri Map services or Feature Services. Am I missing something?
Thank you!
Chris
Check out the doc: CSVLayer | API Reference | ArcGIS API for JavaScript 3.18
