FeatureTable with no mouse events issue
1077
05-26-2019 10:25 PM
BrianBorg1
I am creating a feature table, it is being populated with data but once populated, mouse events on the table are not being fired. I can't select records, sort, etc.  The table froze but the application and map are fine.
 Using code I can manipulate it, for example sorting, select rows, etc but mouse is not working on it. Has any one faced a similar issue?
Egge-Jan_Pollé
Hi Brian Borg‌,
Can you please show us the code you have written so far? It looks like your question is not specific enough to trigger people to answer. As soon as you show what you have got right now, someone might be able to come up with suggestions to improve your application.
HTH,
Egge-Jan
