FeatureTable and "esri-popover" divs
1375
11-12-2020 01:23 PM
KenBuja
MVP Esteemed Contributor
What are all the divs (class="esri-popover") that are added to a page with the FeatureTable (v 4.17)? For example, this sample has nine of these divs. 
Tags (1)
HeatherGonzago
Popover is a helper widget used for showing a floating menu somewhere. It doesn't have to deal specifically with the FeatureTable although this widget uses it as containers for floating column menus.
HeatherGonzago
