Features not changing on executing query
2129
10-18-2023 05:02 AM
wizgis
Hi Community,
I am working on a query app that executes a query based on a condition. I am using the following sample code example for reference purpose : https://developers.arcgis.com/javascript/latest/sample-code/query/
The query app that I am working on seems to work fine as am getting correct number of records for a particular query that gets executed however, the issue is the features are not being returned correctly.
Initially, when I set the same query in map viewer (red dots) and in the application (green dots) features are returned correctly as shown in the first two figures 1 &  2 however, if I change the query in the application and and in map viewer discrepancy is observed as shown in the last two figures 3 & 4.
I am not sure what am I missing here and why features are not being correctly. Any inputs on this would be helpful.
wizgis
Update :
I was able to get it to work by adding the following line of code :
resultsLayer.removeAll(results)
TimDietz
Can you post your before and after queries?  Some code snippets of how it was before vs. now would be helpful.
wizgis
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>Test</title>
    <style>
        html, body,
        #viewDiv{
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%
        #optionsDiv {
        background-color: dimgray;
        color: white;
        padding: 10px;
        width: 350px;
      .esri-popup .esri-popup-header .esri-title {
        font-size: 18px;
        font-weight: bolder;
      .esri-popup .esri-popup-body .esri-popup-content {
        font-size: 14px;
    </style>
      <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.27/esri/themes/light/main.css"
    <script src="script.js"></script>
    <script src="https://js.arcgis.com/4.27/"></script>
    <script>
    require(["esri/config", "esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer", "esri/layers/GraphicsLayer", "esri/rest/query", "esri/rest/support/Query"], function(esriConfig, Map, MapView, FeatureLayer, GraphicsLayer, query, Query){
    esriConfig.apiKey = ""
    const floraURL = ""
    const popupTemplate = {
        title: "{Classification}, {Name}",
        fieldInfos: [
                fieldName: "Classification",
                label: "Classification"
                fieldName: "ParasiteInfection",
                label: "Parasite Infection Identified"
                fieldName: "Threats",
                label: "Threats Identified"
    content: "Classification of Flora : {Classification} <br> " +
    "Any Parasite Infection : {ParasiteInfection} <br>" +
    "Are there any threats that have been identified : {Threats} <br>"
    const resultsLayer = new GraphicsLayer();
    const params = new Query({
          returnGeometry: true,
          outFields: ["*"]
    var map = new Map({
        basemap: "arcgis-topographic",
        layers: [resultsLayer]
    var view = new MapView({
        map: map,
        center: [0,0],
        zoom: 15,
        container: "viewDiv",
        popup: {
            dockEnabled : true,
            dockOptions: {
                position: "top-right",
                breakpoint: false
    view.when(function(){
        view.ui.add("optionsDiv", "bottom-right");
        document.getElementById("doBtn").addEventListener("click", doQuery);
    const attributeName = document.getElementById("attSelect");
    const expressionsign = document.getElementById("signSelect");
    const value = document.getElementById("valSelect");
    function doQuery(){
        params.where = attributeName.value + expressionsign.value + "'" + value.value + "'";
        query
            .executeQueryJSON(floraURL, params)
            .then(getResults)
            .catch(promiseRejected);
    function getResults(response){
        const results = response.features.map(function (feature){
            feature.symbol = {
                type: "simple-marker", // Use simple-marker for 2D symbology
                color: "green", // Set the color of the marker
                size: 10, // Set the size of the marker
                outline: {
                    color: [0, 0, 0, 0.5], // Set the outline color and transparency
                    width: 1 // Set the outline width
            feature.popupTemplate = popupTemplate;
            return feature;
        resultsLayer.addMany(results)
        view.goTo(results).then(function(){
            view.openPopup({
                features: results,
                featureMenuOpen: true,
                updateLocationEnabled: true
        .catch(function (error){
            if (error.name !== "AbourtError"){
                console.error(error);
        document.getElementById("printResults").innerHTML = results.length + "Results Found";
    function promiseRejected(error){
        console.error("Promise Rejected: ", error.message);
    </script>
</head>
<body>
    <div id="viewDiv"></div>
    <div class="esri-widget" id = "optionsDiv">
        <h2>Flora Diversity of Sanjay Van.</h2>
        <select class="esri-widget" id="attSelect">
            <option value="Classification">Classification</option>
        </select>
        <select class="esri-widget" id="signSelect">
            <option value="=">is equal to</option>
        </select>
        <select class="esri-widget" id="valSelect">
            <option value="Herb">Herb</option>
            <option value="Climber">Climber</option>
            <option value="Shrub">Shrub</option>
            <option value="Tree">Tree</option>
            <option value="Grass">Grass</option>
            <option value="Others">Others</option>
        </select>
        <br />
        <br />
        <button class="esri-widget" id="doBtn">Do Query</button> <br />
        <p><span id="printResults"></span></p>
    </div>
</body>
</html>
@TimDietz I am attaching the code snippet that is being used. Based on my understanding and research that I have done so far it feels like I need to have a function/code that removes the features of current query first and then draw new features based on the new query that the user has put.
I am just not sure where and how to add this piece of code.  Any insights would be helpful.
wizgis
Update :
