FeatureLayerView queryFeatures doesn't return features for aggregates
883
04-08-2024 10:28 AM
saqibqureshi
Following code snippets works perfectly until data in the layer is refreshed again after initial load. Once data is reloaded the following code doesn't list features from the layerview for a cluster.
Once map is zoomed In/Out, the query starts working again. I think the layerView needs refresh, but there is nothing I could find to do that.
const { results } = await view.hitTest(evt, { include: featureLayer });
if (results[0].graphic.isAggregate) {
    const layerView = await view.whenLayerView(featureLayer);
    const query = layerView.createQuery();
    query.aggregateIds = [results[0].graphic.getObjectId()];
    const { features } = await layerView.queryFeatures(query);
    console.log(features.length + " features found");
UndralBatsukh
Hi there,
I am not able to reproduce the behavior you are referring to. Can you please provide a simple codepen that shows the behavior in question? Which version of the API are you using?
