featureLayer.setSelectionSymbol(symbol) not working
3742
07-27-2016 10:10 AM
lasinh
i created featureLayer based on a feature collection; and i added this featureLayer  to my map; then i query features by Extent and objectId and my code return list features but not set symbol of features? how to set symbol of features returned from the query feature collection featurelayer;
below mycode:
require(["esri/map",
    "esri/layers/ArcGISTiledMapServiceLayer",
    "esri/dijit/PopupTemplate",
    "esri/layers/FeatureLayer",
    "esri/tasks/query",
    "esri/geometry/Circle",
    "esri/graphic",
    "esri/InfoTemplate",
    "esri/symbols/SimpleMarkerSymbol",
    "esri/symbols/SimpleLineSymbol",
    "esri/symbols/SimpleFillSymbol",
    "esri/Color",
    "esri/renderers/SimpleRenderer",
    "esri/geometry/Point",
    "dojo/_base/array",
    "dojo/on",
    "dojo/dom",
    "esri/layers/ArcGISDynamicMapServiceLayer",
    "dojo/domReady!"],
    function (Map,
        ArcGISTiledMapServiceLayer,
        PopupTemplate,
        FeatureLayer,
        Query,
        Circle,
        Graphic,
        InfoTemplate,
        SimpleMarkerSymbol,
        SimpleLineSymbol,
        SimpleFillSymbol,
        Color,
        SimpleRenderer,
        Point,
        arrayUtils,
        on,
        dom,
        ArcGISDynamicMapServiceLayer) {
        var map;
        var featureLayer;
        map = new Map("mapDiv", {
        var tiled = new ArcGISTiledMapServiceLayer("url");
        map.addLayers([tiled]);
        var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          12,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_NULL,
            new Color([247, 34, 101, 0.9]),
          new Color([207, 34, 171, 0.5])
        var circle;
        var circleSymb = new SimpleFillSymbol(
          SimpleFillSymbol.STYLE_NULL,
            SimpleLineSymbol.STYLE_SHORTDASHDOTDOT,
            new Color([105, 105, 105]),
          ), new Color([255, 255, 0, 0.25])
        var fields = [
             alias: "ObjectID",
             type: "esriFieldTypeOID"
             alias: "matrai",
             type: "esriFieldTypeString"
             alias: "tentrai",
             alias: "loaiTrangTrai",
        var pTemplate = new PopupTemplate({
            title: "{tentrai}",
            description: "{loaiTrangTrai}"
        map.on("layers-add-result", function () {
            $.ajax({
                type: "POST",
                url: "trangchu.aspx/GetPointJsonString",
                contentType: "application/json; charset=utf-8",
                dataType: "json", // dataType is json format
                success: function (data) {
                    var obj = JSON.parse(data.d);
                    var features = [];
                    $.each(obj, function (index, val) {
                        index = index + 1;
                        var feature = {
                            geometry: new Point({
                                x: val.toadox,
                                y: val.toadoy,
                                spatialReference: map.spatialReference
                            // select only the attributes you care about
                            attributes: {
                                ObjectID: index,
                                matrai: val.matrai,
                                tentrai: val.tentrai,
                                loaiTrangTrai: val.loaiTrangTrai
                        features.push(feature);
                    var featureCollection = {
                        "layerDefinition": {
                            "geometryType": "esriGeometryPoint",
                            "objectIdField": "ObjectID",
                            "drawingInfo": {
                                "renderer": {
                                    "type": "simple",
                                    "symbol": {
                                        "type": "esriPMS",
                                        "url": "Images/GreenPin1LargeB.png",
                                        "contentType": "image/png",
                                        "width": 12,
                                        "height": 12
                            "fields": fields
                        "featureSet": {
                            "features": features,
                    featureLayer = new FeatureLayer(featureCollection, {
                        allowGeometryUpdates: true,
                        infoTemplate: pTemplate
                    map.addLayers([featureLayer]);
                    featureLayer.on("Click", function (evt) {
                        //    map.infoWindow.setFeatures([evt.graphic]);
                error: function (errorText) {
                    alert(errorText);
        map.on("Click", function (evt) {
            circle = new Circle({
                center: evt.mapPoint,
                radius: 1,
                radiusUnit: "esriMiles"
            map.graphics.clear();
            map.infoWindow.hide();
            var graphic = new Graphic(circle, circleSymb);
            map.graphics.add(graphic);
            var query = new Query();
            query.geometry = circle.getExtent();
            featureLayer.queryFeatures(query, selectInBuffer);
        function selectInBuffer(response) {
            var feature;
            var features
            features = response.features;
            var inBuffer = [];
            for (var i = 0; i < features.length; i++) {
                feature = features;
                if (circle.contains(feature.geometry)) {
                    inBuffer.push(feature.attributes[featureLayer.objectIdField]);
            query.objectIds = inBuffer;
            featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function (results) {
                featureLayer.setSelectionSymbol(symbol);
RobertScheitlin__GISP
La Sinh,
  Have you tried setting the selection symbol outside/before your selectFeatures function?
lasinh
thanks Robert Scheitlin  i tried  setSelectionSymbol  before selectFeatures function but my code not work?
    "esri/tasks/query",
    "esri/graphic",
    "esri/Color",
    "dojo/_base/array",
    "dojo/on",
    "dojo/dom",
    "dojo/domReady!"],
    function (Map,
        PopupTemplate,
        FeatureLayer,
        Query,
        Circle,
        Graphic,
        InfoTemplate,
        SimpleMarkerSymbol,
        SimpleLineSymbol,
        SimpleFillSymbol,
        Color,
        SimpleRenderer,
        Point,
        arrayUtils,
        on,
        dom,
        var map;
        var featureLayer;
          12,
        var circle;
        var fields = [
             alias: "ObjectID",
             alias: "matrai",
             alias: "tentrai",
            title: "{tentrai}",
            $.ajax({
                type: "POST",
                    var features = [];
                        index = index + 1;
                        var feature = {
                                x: val.toadox,
                                y: val.toadoy,
                            attributes: {
                                ObjectID: index,
                                matrai: val.matrai,
                            "drawingInfo": {
                                "renderer": {
                                    "type": "simple",
                                    "symbol": {
                                        "type": "esriPMS",
                                        "width": 12,
                                        "height": 12
                            "fields": fields
                        "featureSet": {
//  featureLayer.setSelectionSymbol(symbol);
                    alert(errorText);
                radius: 1,
            var feature;
            var features
            var inBuffer = [];
                feature = features;
la sinh,
Are you sure that you have features being selected? Have you tried to put a console statement in the selectFeatures function?
lasinh
i get features atrrbutes and put this features console, but not set symbol this feature selected
La Sinh,
  SO you are saying that you do get something in the console when you have this code:
   console.info(results);
