FeatureLayer Selection Print Issue
2039
01-28-2016 07:42 AM
RyanSellman
Hello All,
I have noticed an issue in one of my apps when trying to print (with Export Web Map task) with features from a Feature Layer selected.  The print task successfully runs, however every time I try to create a printout when more than one feature is selected, only one feature displays on the map.  Below is the code I use to create the selection:
var parcelsUrl = "http://summitmaps.summitoh.net/arcgis/rest/services/ParcelQuery/MapServer/1";
         featureLayerParcel = new esri.layers.FeatureLayer(parcelsUrl, {
             mode: esri.layers.FeatureLayer.MODE_SELECTION,
             visible: true,
             id: "Attribute Selection",
             outFields: ["*"]
         var symbol = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_NULL, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new dojo.Color([0, 255, 255]), 2), new dojo.Color([0, 0, 255, 0.20]));
         featureLayerParcel.setSelectionSymbol(symbol);
         map.addLayer(featureLayerParcel);
         function queryParcels() {
             featureLayerParcel.clearSelection();
             parcelQuery.clearSelection();
             domUtils.show(parcelSearchLoad);
             var queryParcels = new esri.tasks.Query();
             //switch where clause based selected search field
             queryParcels.where = "PARID LIKE '" + "%" + dom.byId("parcelText").value + "'";
             if (dom.byId("attributeSelector").value === "PARID") {
                 queryParcels.where = "PARID LIKE '" + "%" + dom.byId("parcelText").value + "%" + "'";
             } else if (dom.byId("attributeSelector").value === "ADDR") {
                 queryParcels.where = "ADRNO LIKE '" + dom.byId("addrNum").value + "%" + "'" + "AND ADRSTR LIKE '" + dom.byId("addrText").value + "%" + "'";
             } else {
                 queryParcels.where = "OWN1 LIKE '" + "%" + dom.byId("ownerText").value + "%" + "'";
             featureLayerParcel.selectFeatures(queryParcels, esri.layers.FeatureLayer.SELECTION_NEW, function(features, selectionMethod) {
                 parcelSelection = [];
                 totalParcels = features.length;
                 document.getElementById("selectedParcels").innerHTML = features.length;
                 document.getElementById("totalNumberSelected").innerHTML = features.length;
                 for (var i = 0, il = features.length; i < il; i++) {
                     parcelSelection.push(features.attributes.PARID);
                 console.log(parcelSelection);
                 var newStore = new ItemFileReadStore({
                     data: {
                         idenitifer: "",
                         items: []
                 var grid = registry.byId("grid2");
                 grid.setStore(newStore);
                 if (features.length === 1) {
                     document.getElementById("parcelPosition").innerHTML = features.length;
                     var feature = features[0];
                     var parid = feature.attributes.PARID;
                     selectParcel(parid);
                     domUtils.hide(parcelSearchLoad);
                 } else if (features.length > 1) {
                     var parcelItems = dojo.map(features, function(feature) {
                         return feature.attributes;
                     var parcelData = {
                         identifier: "OBJECTID",
                         items: parcelItems
                     var parcelStore = new dojo.data.ItemFileReadStore({
                         data: parcelData
                     var parcelGrid = registry.byId("grid2");
                     parcelGrid.on("rowclick", onRowClickHandler);
                     parcelGrid.setStore(parcelStore);
                     map.setExtent(graphicsUtils.graphicsExtent(featureLayerParcel.getSelectedFeatures()), true);
                 } else {
                     alert("No Parcels found!");
             document.getElementById("oldTaxMapWidget").style.display = "none";
In the webmap JSON sent to the print task, the objectIds for the selected features are included.  See snippet from JSON below:
         "id":"Attribute Selection",
         "title":"Attribute Selection",
         "opacity":1,
         "minScale":0,
         "maxScale":0,
         "layerDefinition":{
            "drawingInfo":{
               "renderer":{
                  "type":"simple",
                  "symbol":{
                     "color":[
                        0,
                        0,
                        255,
                        51
                     "outline":{
                        "color":[
                           0,
                           255,
                           255,
                           255
                        "width":1.5,
                        "type":"esriSLS",
                        "style":"esriSLSSolid"
                     "type":"esriSFS",
                     "style":"esriSFSNull"
            "objectIds":[
                  26764885
                  26764886
                  26765418
                  26765419
                  26765540
                  26765541
                  26765542
         "url":"http://summitmaps.summitoh.net/arcgis/rest/services/ParcelQuery/MapServer/1"
See the attached image.  In this case there are 7 features selected but in the output of the print task just one feature is shown.  Has anyone had this issue?  Any help is appreciated!
Ryan
