FeatureLayer.grahics is empty
2412
01-16-2014 04:07 AM
MaxDemars
I am new to the javascript API and I dont know what is going wrong in my simple map application. I have a map servcie published by arcgis Server and I would like to select a layer of this service to use in a geoprocessing tool. However, I cant retrieve the graphics of this layer.
I am doing like this:
     require(["esri/map", "dojo/domReady!", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/FeatureLayer", "esri/tasks/Geoprocessor", "esri/SpatialReference",], function(Map) {  /*initializing map, etc... */  var school = new esri.layers.FeatureLayer("http://localhost:6080/arcgis/rest/services/carte1/MapServer/0");    //trying to retieve the graphics with load event because the map service is asynchronous            school.on("load", function(){      inputFeatures.features = school.graphics;      inputFeatures.fields = school.dataAttributes;      alert(inputFeatures.features) //the alert box is empty     }); });
Why can't I get the graphics like this?
Thank you,
JohnathanBarclay
var query = new Query(); query.where = "1=1"; school.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(result){   console.log(result);//This is an array of graphics })
Still cant get the graphics from the selection I do like this:
      function setupParameters(){          var inputFeatures = new esri.tasks.FeatureSet();          var query = new esri.tasks.Query();          query.where = "1=1";          var school = new esri.layers.FeatureLayer("http://localhost:6080/arcgis/rest/services/carte1/MapServer/0",{             mode: esri.layers.FeatureLayer.MODE_SNAPSHOT,           });          map.addLayer(school);          school.on("update-end", function(){          school.selectFeatures(query, esri.layers.FeatureLayer.SELECTION_NEW, function(result){                inputFeatures.features = result.graphics;                console.log(inputFeatures.features)          });         });
console.log returns "undefined"
You were nearly there; the selectFeatures callback returns an array of graphics, so its simply:
inputFeatures.features = result; console.log(inputFeatures.features);
JakubMalec
Documentation says:
The features are retrieved once the feature layer is added to the map. After the onUpdateEnd event has fired
If you want to get features from current extent, you need to initialize the layer in MODE_ONDEMAND mode. If you want to get all features, you need to set the mode to MODE_SNAPSHOT (but it will return no more than the default total of 1000 features).
Read more at: https://developers.arcgis.com/en/javascript/jsapi/featurelayer.html
MaxDemars
Documentation says:
Thank you for your reply. What can I do if I dont want to add this layer to the map? How can I retrieve its graphics anyway?
Ok in MODE_SNAPSHOT I think I could retrieve more than 1000 features if I change the default property in ArcGIS Server Manager.
JohnathanBarclay
First create the map then add the layer as follows:
var map = new Map("mapDiv");
Via the FeatureLayer's selectFeatures() method. You will need to define a Query first (require "esri/tasks/query"), but if you want to retrieve all features you can set the Query's where property to "1=1":
What? It is impossible to get more than 1000 features? Why this limitation?
No you can change the limit in the service itself:
1. Open ArcCatalog and browse to your service
2. Right click and select Service Properties (service must be stopped first)
3. Select the Parameters tab, then change the "Maximum Number of Records Returned by Server" to your desired amount
MaxDemars
JohnathanBarclay
