FeatureLayer centerAt
563
07-02-2013 12:16 AM
MARCHANDMathieu
Hi all,
Someone can help me please.
I build a widget with combobox.
When I select combobox lign, I want to display and centerAt to this object(point) with my toggleLayer function.
This works well, but if I comment alert("Ok");, it don't work....!?
toggleLayer: function(item){
        //--return intial feature extent
  this.map.setExtent(featureLayer.fullExtent);
  //--apply a definition expression to the layer to only display objects of the selected theme
        var query = "ETIQUETTE='${name}'";
        //--display point
        featureLayer.setScaleRange(0,0);
        featureLayer.setDefinitionExpression(esri.substitute({
        }, query));
        //--zoom to point
        var geom;
  var query2 = new esri.tasks.Query();
        query2.where = "1=1 AND ETIQUETTE='"+item+"'";
        query2.returnGeometry = true;
        query2.outSpatialReference = this.map.spatialReference;
        query2.orderByFields = ["ID_BUREAU ASC"];
        featureLayer.selectFeatures(query2, esri.layers.FeatureLayer.SELECTION_NEW);
        dojo.connect(featureLayer, "onSelectionComplete", function(results) {
                geom = results[0].geometry;
 alert("Ok");
 this.map.centerAt(new esri.geometry.Point(geom));
Thank you.
[Math - French developper]
