ArcGIS API for Fleet Management
3008
06-30-2013 11:12 AM
AdelekeAkinsanya
I am a final year student currently working on an ASP.NET fleet management system using web services as thesis. I need to be able to pass simulated position coordinates (longitude and latitude) and be able to triangulate the position of a vehicle on a map. I am a little confused on how to get this done. I will appreciate any information that can point me in the right direction please. Thanks so much.
JonathanUihlein
If you haven't looked at the tutorials and samples yet, give it a shot.
https://developers.arcgis.com/en/javascript/jstutorials/
As far as displaying a point on a map using location information: this is the right place!
You can map an object based on address or geographic coordinates (lat/long, in your case).
Example: If you have the latitude and longitude of a location, you could create a point object and display this point on a map using a geocoder.
Examples are here: https://developers.arcgis.com/en/javascript/jssamples/#geocoding
However, I'm not sure about triangulation. You might need someone else to help you with that.
