FeatureLayer & ArcGISDynamicMapServiceLayer
989
11-12-2012 06:52 AM
GyeyoungChoi
I was making a map with popup function however I'm stuck or have no idea using
        var featureLayer = new esri.layers.FeatureLayer("http://localhost/ArcGIS/rest/services/TAVP/MapServer",{
   opacity:0.5,
   mode: esri.layers.FeatureLayer.MODE_SELECTION,
   outFields: ["*"],
   infoTemplate:template
it works when I change new esri.layers.FeatureLayer to new esri.layers.ArcGISDynamicMapServiceLayer
but then popup will not work.
Can anyone help me out with this?
URL working fine and map as well
JohnGravois
hi jack,
a feature layer needs to have the index of a layer in a map service specified.  check out the following article for more information.
ie. the following is a valid FeatureLayer...
http://services.arcgisonline.com/ArcGIS/rest/services/Demographics/USA_1990-2000_Population_Change/M...
while the url below is a reference to the map service itself (and would be a valid ArcGISDynamicMapServiceLayer
check out each link in the browser to see the Rest endpoint for each resource to compare and contrast what is returned.
GyeyoungChoi
Thanks,  I just figure out what was wrong
