Featureeffect issue
170
05-20-2025 11:51 PM
banu
<!doctype html>
<html lang="en">
<head>
<meta charset="utf-8" />
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
<title>Intro to FeatureLayer | Sample | ArcGIS Maps SDK for JavaScript 4.32</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.29/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.29/"></script>
<style>
html,
body,
#viewDiv {
padding: 0;
margin: 0;
height: 100%;
width: 100%;
.tree {
--spacing: 1.5rem;
--radius: 10px;
.tree li {
display: block;
position: relative;
padding-left: calc(2 * var(--spacing) - var(--radius) - 2px);
.tree ul {
margin-left: calc(var(--radius) - var(--spacing));
padding-left: 0;
</style>
<script>require(["esri/Map", "esri/views/MapView", "esri/layers/FeatureLayer","esri/layers/support/FeatureFilter","esri/layers/support/FeatureEffect"], (Map, MapView, FeatureLayer,FeatureFilter,FeatureEffect) => {
const map = new Map({
basemap: "hybrid"
const view = new MapView({
container: "viewDiv",
map: map,
extent: {
xmin: -9177811,
ymin: 4247000,
xmax: -9176791,
ymax: 4247784,
spatialReference: 102100
//center: [45.0792, 23.8859]
//zoom: 6
view.popup.defaultPopupTemplateEnabled=true;
let layer = new FeatureLayer({
url: "https://services.arcgis.com/V6ZHFr6zdgNZuVG0/arcgis/rest/services/Landscape_Trees/FeatureServer/0"
map.add(layer);
document.getElementById("btnCustomLayerList").onclick = function () {
document.getElementById("customLayerList").style.display = "block";
document.getElementById("btnClearCustomLayerList").onclick = function () {
document.getElementById('ulTreeDiv1').innerHTML="";
document.getElementById('selDepartment').selectedIndex = 0;
layer.definitionExpression = "1=1";
view.ui.add(btnCustomLayerList, "top-right");
//#region custom LayerList
var divList = []; var divList2 = [];
var featureLayerView;
view.when(() => {
view.whenLayerView(layer).then((layerView) => {
featureLayerView = layerView;
layer.when(() => {
const rootdivtLL = document.getElementById("customLayerList");
//#region Query Dept
layer.queryFeatures({
where: "1=1",
outFields: ["Condition"],
returnDistinctValues: true
}).then((featureSet) => {
if (featureSet.features.length > 0) {
//#region Root
var label = document.createElement('label')
label.htmlFor = "selDepartment";
label.appendChild(document.createTextNode("Department: "));
rootdivtLL.appendChild(label);
const selectElement = document.createElement('select');
selectElement.name = "selDepartment";
selectElement.id = "selDepartment";
const optionElement = document.createElement('option');
optionElement.value = "0";
optionElement.text = "select dept";
selectElement.appendChild(optionElement);
for (let i = 1; i < featureSet.features.length + 1; i++) {
if (featureSet.features[i - 1].attributes["Condition"] == null) continue;
optionElement.value = featureSet.features[i - 1].attributes["Condition"];
optionElement.text = featureSet.features[i - 1].attributes["Condition"];
selectElement.addEventListener("change", selDepartmentChanged);
function selDepartmentChanged(event) {
//layer.definitionExpression = "Condition='"+event.target.value+"'";
//#region FadeInOut
const featureFilter1 = new FeatureFilter({
where: "Condition='"+event.target.value+"'"
featureLayerView.featureEffect = new FeatureEffect({
filter: featureFilter1,
includedEffect: "drop-shadow(3px, 3px, 3px, black)",
excludedEffect: "blur(1px) brightness(20%)"
//#endregion
const elementToRemove = document.getElementById('ulTreeDiv1');
if (elementToRemove) elementToRemove.remove();
where: "Condition='"+event.target.value+"'",
outFields: ["Street"],
//#region Tree
var ulTreeDiv1 = document.createElement('ul');
ulTreeDiv1.id = "ulTreeDiv1";
ulTreeDiv1.className = "tree";
var liTreeDiv1 = document.createElement('li');
ulTreeDiv1.appendChild(liTreeDiv1);
var detailsTreeDiv1 = document.createElement('details');
detailsTreeDiv1.open = true;
liTreeDiv1.appendChild(detailsTreeDiv1);
var summaryTreeDiv1 = document.createElement('summary');
var checkbox = document.createElement('input');
checkbox.type = "checkbox";
checkbox.id = "divTree";
checkbox.value = event.target.value;
checkbox.checked = true;
summaryTreeDiv1.appendChild(checkbox);
label.htmlFor = "divTree";
label.appendChild(document.createTextNode(event.target.value));
summaryTreeDiv1.appendChild(label);
detailsTreeDiv1.appendChild(summaryTreeDiv1);
var ulSubTreeDiv1 = document.createElement('ul');
detailsTreeDiv1.appendChild(ulSubTreeDiv1);
featureSet.features.forEach((feature, index) => {
if (feature.attributes["Street"] == null) return;
divList.push("'"+feature.attributes["Street"]+"'");
var liSubTreeDiv1 = document.createElement('li');
ulSubTreeDiv1.appendChild(liSubTreeDiv1);
var detailsSubTreeDiv1 = document.createElement('details');
detailsSubTreeDiv1.open = true;
detailsSubTreeDiv1.id = "detailsTree" + feature.attributes["Street"];
liSubTreeDiv1.appendChild(detailsSubTreeDiv1);
var summarySubTreeDiv1 = document.createElement('summary');
var checkboxSub = document.createElement('input');
checkboxSub.type = "checkbox";
checkboxSub.id = "divSubTree" + index.toString();
checkboxSub.value = feature.attributes["Street"];
checkboxSub.checked = true;
checkboxSub.addEventListener("click", (event2) => {
if (event2.target.checked)
divList.push("'"+event2.target.value+"'");
else {
const index = divList.indexOf("'"+event2.target.value+"'");
const x = divList.splice(index, 1);
//layer.definitionExpression = divList.length === 0 ? "Condition='"+document.getElementById("selDepartment").value+"'" : "Condition='"+document.getElementById("selDepartment").value +"' and Street in ("+divList.join(",")+")";
//#region FadeInOut
const featureFilter2 = new FeatureFilter({
where: divList.length === 0 ? "Condition='"+document.getElementById("selDepartment").value+"'" : "Condition='"+document.getElementById("selDepartment").value +"' and Street in ("+divList.join(",")+")"
filter: featureFilter2,
//#endregion
//#region check/uncheck
const checkboxes = document.getElementById("ulSubSub"+event2.target.value).querySelectorAll('input[type="checkbox"]');
checkboxes.forEach(checkbox => {
checkbox.checked = event2.target.checked;
//#endregion
summarySubTreeDiv1.appendChild(checkboxSub);
var labelSub = document.createElement('label')
labelSub.htmlFor = "divSubTree" + index.toString();
labelSub.appendChild(document.createTextNode(feature.attributes["Street"]));
summarySubTreeDiv1.appendChild(labelSub);
detailsSubTreeDiv1.appendChild(summarySubTreeDiv1);
//#region a
where: "Condition='"+event.target.value+"' and Street= '"+feature.attributes["Street"]+"'",
outFields: ["FID"],
}).then((featureSet2) => {
if (featureSet2.features.length > 0) {
var detailsSubTreeDiv1 = document.getElementById("detailsTree"+feature.attributes["Street"]);
var ulSubSubTreeDiv1 = document.createElement('ul');
ulSubSubTreeDiv1.id = "ulSubSub"+feature.attributes["Street"];
featureSet2.features.forEach((feature2, index2) => {
divList2.push(feature2.attributes["FID"]);
//#region a
var liSubSubTreeDiv1 = document.createElement('li');
checkbox.id = "div11Tree" + index2.toString();
checkbox.value = feature2.attributes["FID"];
checkbox.addEventListener("click", (event3) => {
if (event3.target.checked)
divList2.push(event2.target.value);
else {
const index = divList2.indexOf(event3.target.value);
const x = divList2.splice(index, 1);
//layer.definitionExpression = divList2.length === 0 ? "Condition='"+document.getElementById("selDepartment").value+ "' and Street in ("+divList.join(",")+")" : "Condition='"+document.getElementById("selDepartment").value+"' and Street in ("+divList.join(",")+") and FID in ("+divList2.join(",")+")";
//#region FadeInOut
const featureFilter3 = new FeatureFilter({
where: divList2.length === 0 ? "Condition='"+document.getElementById("selDepartment").value+ "' and Street in ("+divList.join(",")+")" : "Condition='"+document.getElementById("selDepartment").value+"' and Street in ("+divList.join(",")+") and FID in ("+divList2.join(",")+")"
filter: featureFilter3,
//#endregion
//#region checkuncheck same items
var checkboxes = document.querySelectorAll('input[value="' + event3.target.value + '"]');
checkboxes.forEach(checkbox1 => {
checkbox1.checked = event3.target.checked;
//#endregion
liSubSubTreeDiv1.appendChild(checkbox);
label.htmlFor = "div11Tree" + index2.toString();
label.appendChild(document.createTextNode(feature2.attributes["FID"]));
liSubSubTreeDiv1.appendChild(label);
ulSubSubTreeDiv1.appendChild(liSubSubTreeDiv1);
//#endregion
detailsSubTreeDiv1.appendChild(ulSubSubTreeDiv1);
//#endregion
rootdivtLL.appendChild(ulTreeDiv1);
//#endregion
rootdivtLL.appendChild(selectElement);
//#endregion
//#endregion
//#endregion
});</script>
</head>
<body>
<div id="viewDiv">
<button id="btnCustomLayerList">Filter</button>
<button id="btnCClearustomLayerList">Clear</button>
<div id="customLayerList" style="display:none">
</div>
</div>
</body>
</html>
