Feature service Token
983
09-11-2022 01:17 AM
Guy_srb
Hi!
I have a problem using a secured feature service.
  esriConfig.request.interceptors.push({
    urls: FeatureLayerURL,
    before: function(params) {
      params.requestOptions.query = params.requestOptions.query || {};
      params.requestOptions.query.token = token;
the code does work until I try to Edit features(using EditorViewModel) and then the portal login screen popup appear.
Guy_srb
Found a  better solution, I used this code:
  esriId.registerToken({
    server: FeatureLayerURL,
    token: token
esriID is from the library "esri/identity/IdentityManager"
Guy_srb
    token: token
