Feature Layer Name undefined?
3946
08-03-2012 04:37 AM
AdamWills
This may be something silly that I'm doing wrong, but my feature layer name keeps coming back as undefined.
console.log(featureLayer) produces this:
a ->
console.log(featureLayer.id) produces "graphicsLayer4"
console.log(featureLayer.name) produces "undefined"
Any ideas what I'm doing wrong?
danbecker
from the api reference:
"The name of the layer as defined in the map service."
a ->
console.log(featureLayer.name) - would return the name of the layer as defined in the service. Doesn't look like you can define name, only properties listed in the 'constructor detail' section of the api reference.
AdamWills
I'm not looking to define the name - just want to return the name in the service.  But it keeps returning undefined.
RahulMetangale1
Since name is coming from map service you have to wait till layer is added to map then only you can access its properties like name. Here is the sample code to retrieve the name from feature layer:
dojo.connect(featureLayer,"onLoad",function(){
alert(featureLayer.name);
Here is the complete sample:
http://jsfiddle.net/rahulm/nGc9b/
AdamWills
Perhaps I'm just confused as to when I log the object, I get the name returned, but when I try to access that property, I can't.
Edit: And I can access other properties, such as the id and url....
ChristianDebono
I have the same problem. Have you came up with a solution for it?
