Feature Layer - label placement for polygons
916
10-09-2024 03:14 PM
DavidFriedrich_DEV
When creating a map via Pro and using the standard labeling engine, for a polygon layer, I have the following three options for label placement:
a) Always horizontal
b) Always Straight
c)Try horizontal first, then straight.
However, when using the Javascript SDK, adding this same layer as a FeatureLayer, using the "labelingInfo" property, I am not able to utilize any of the "labelPlacement" options except "always-horizontal".
Is there any way to utilize the other two options in a Javascript SDK app?
JoelBennett
MVP Regular Contributor
Unfortunately, there is not.  As seen in the "Known Limitations" section near the top of the LabelClass documentation, "Polygon geometries only support always-horizontal labelPlacement."
Further below, the documentation for the labelPlacement property only gives the single option for polygons as well.
