Feature Layer double TAP point
7661
12
05-15-2014 12:17 PM
JeffPace
I am having trouble listening for a double tap event on a feature layer point.
Click and dbl click work fine on the desktop.  Tap works fine to select a point on iOS.  But I can't seem to get doubletap to fire
I even tried using the dojox/gestures but to no avail
Any ideas?
JonathanUihlein
Jeff is right that it is being looked at.
There are some 'gotchas' in different device/browser combos which, unfortunately, require their own specific logic.
Ideally, there would be events for tap, swipe, drag and hover. There are some fantastic use-cases for each of these.
No ETA yet but this enhancement may end up being a part of 4.0 if time is an issue.
JeffPace
Thank you.  It is nice to know its on the list so to speak, so I dont have to spend alot of time on work arounds.
Thanks Jonathan Uihlein
JeffPace
Jonathan Uihlein‌ is doubletap still being looked at? it is still not working in 3.12
