Extrude: changing building footprint height using slider
1919
02-15-2017 03:02 PM
by Anonymous User
Not applicable
How to seamlessly change a selected building footprint height (extrude) using HorizontalSlider?
Currently, my code works something like this:
Click a building -> change color of building and assign max height value (how tall the building can be) to slider and label
Use the horizontal slider to change height -> click back the selected building to change height (!!! this needs to be done by the slider).
I think something to do with slider onChange, but I am not sure...  How to change building footprint height using the slider?
FC_Basson
Your building footprint will be based on a defition query, so in the slider's onchange event you must get the slider value and apply it to the building feature layer definition query
Something like this:
onChange: function(value){
  dom.byId("sliderValue").value = number.format(value, {places:0});
  buildingLayer.definitionExpression = "ELEVATION > " + value.toString();
where ELEVATION is the feature layer attribute field indicating the building height.
by Anonymous User
Not applicable
Hi FC Basson,
Thank you so much for your response.  I tested your code and had a fun filtering buildings by height.  It is definitely good to remember!!
It seems my question wasn't clear enough. I would like to extrude the selected building seamlessly using slider input.  I included my code below this time (I am new to dojo/dijit so I am learning it as I go).  I think line 26 to 29 needs to be onChange event (while the slider is moving, keep render the renderer).  How can I achieve this?  I know attached code is a little too long for the post, but I hope this provides some ideas what I am trying to do.  I appreciate any of your input.
onOpen: function(){
      console.log('onOpen');
      var footprintL = this._startUpExtrude();
      var sliderUI = this._initSliderUI();
      this._getFeatureLayerAttributes().then(lang.hitch(this, function(building){
        // Get the building footprint attributes
        var buildingData = building.attributes;
        var uniqueValueInfos = building.uniqueValueInfos; // PolygonSymbol3D/ExtrudeSymbol3DLayer
        // Click event
        this.sceneView.on('click', lang.hitch(this, function(event){
            this.sceneView.hitTest(event.screenPoint).then(function(res){
            var attributes = res.results[0].graphic.attributes; //OBJECTID & Building_Height
            //Update slider label to Z_Max ---> !!! See dijit Basics to see there is another way to do the same
            var zMaxLabel = number.format(buildingData[attributes.OBJECTID - 1].Z_Max, {places: 0});
            var last = dojo.query(".dijitRuleLabelContainer").last();
            last[0].textContent = zMaxLabel;
            //Update slider maximum value ---> !!! See dijit Basics to see there is another way to do the same
            zMaxNum = Number(zMaxLabel);
            sliderUI.slider.maximum = zMaxNum;
            // Change selected building height
            var symbol = new PolygonSymbol3D({
                symbolLayers: [new ExtrudeSymbol3DLayer({
                              material: { color: [255, 0, 0, 0.85] } })]
            uniqueValueInfos[attributes.OBJECTID -1 ] = {value: attributes.OBJECTID, symbol:symbol};
            var renderer = new UniqueValueRenderer({
              field: "OBJECTID",
              uniqueValueInfos: uniqueValueInfos,
              visualVariables: [{ valueUnit: 'feet' }]
            footprintL.renderer = renderer;
FC_Basson
According to the base class dijit/form/HorizontalSlider documentation the widget only has an "onChange" event, so you have to release the the slider handle to fire the event.  If you use an <input type="range"> element as slider, you could use the "oninput" event as a listener for continuous value change while dragging the handle, but you loose all the fancy styling of the widget.
by Anonymous User
Not applicable
Thank you so much for your response!  It seems like there is no easy way to do so that I decided to use "submit" button.
