ExtractData Dijit
3057
6
01-31-2018 02:18 PM
JohnCartwright3
Hello All,
I'm having a little trouble getting the the ExtractData dijit ("esri/dijit/analysis/ExtractData") working using JSAPI 3.23.
var extractData = new ExtractData({
    featureLayers: layers,
    map: map,
    analysisGpServer: "https://gisdev.ngdc.noaa.gov/arcgis/rest/services/extract/hazards_extract/GPServer"
}, "analysis-tool");
extractData.startup();
Besides the styling being incorrect, I'm getting an "Cannot read property 'indexOf' of undefined" error out of the dijit.
Can anyone provide me an example of how to set this dijit up?
Thanks!
--john
RobertScheitlin__GISP
Ken, I hope you don't mind me jumping in.
John, You issue is simple your app needs a dojo theme applied.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Simple Map</title>
  <link rel="stylesheet" href="https://js.arcgis.com/3.23/esri/css/esri.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.23/dijit/themes/claro/claro.css">
  <style>
    html,
    body,
    #map {
      height: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script src="https://js.arcgis.com/3.23/"></script>
  <script>
    var map;
    require([
      "dojo/on",
      "esri/config",
      "esri/map",
      "esri/layers/ArcGISDynamicMapServiceLayer",
      "esri/layers/FeatureLayer",
      "esri/dijit/analysis/ExtractData",
      "esri/geometry/Extent",
      "esri/tasks/Geoprocessor",
      "dojo/domReady!"
    ], function(on, esriConfig, Map, ArcGISDynamicMapServiceLayer, FeatureLayer, ExtractData, Extent, Geoprocessor) {
      esriConfig.defaults.io.corsEnabledServers.push('maps.ngdc.noaa.gov');
      esriConfig.defaults.io.corsEnabledServers.push('gis.ngdc.noaa.gov');
      esriConfig.defaults.io.corsEnabledServers.push('gisdev.ngdc.noaa.gov');
      var aoi = new Extent(-44, -9, -41, 0);
      console.log(aoi.toJson());
      map = new Map("map", {
        basemap: "topo", //For full list of pre-defined basemaps, navigate to http://arcg.is/1JVo6Wd
        center: [-122.45, 37.75], // longitude, latitude
        zoom: 6
      var layer = new ArcGISDynamicMapServiceLayer(
        "https://gis.ngdc.noaa.gov/arcgis/rest/services/web_mercator/hazards/MapServer", {
      map.addLayer(layer);
      var layers = [
        new FeatureLayer("https://gisdev.ngdc.noaa.gov/arcgis/rest/services/extract/hazards_extract/MapServer/0", {
          id: 'Retrospective DART Deployments'
        new FeatureLayer("https://gisdev.ngdc.noaa.gov/arcgis/rest/services/extract/hazards_extract/MapServer/1", {
          id: 'Current DART Deployments'
        new FeatureLayer("https://gisdev.ngdc.noaa.gov/arcgis/rest/services/extract/hazards_extract/MapServer/2", {
          id: 'Volcano Locations'
        new FeatureLayer("https://gisdev.ngdc.noaa.gov/arcgis/rest/services/extract/hazards_extract/MapServer/3", {
          id: 'Signifigant Earthquakes'
        new FeatureLayer("https://gisdev.ngdc.noaa.gov/arcgis/rest/services/extract/hazards_extract/MapServer/4", {
          id: 'Tsunami Observations'
        new FeatureLayer("https://gisdev.ngdc.noaa.gov/arcgis/rest/services/extract/hazards_extract/MapServer/5", {
      map.addLayers(layers);
      on(this.map, 'layers-add-result', function() {
        console.log('layers added');
          map: map,
      console.log('here');
  </script>
</head>
<body class="claro">
  <div id="map"></div>
  <hr>
  <br>
  <div id="analysis-tool"></div>
</body>
</html>
KenBuja
MVP Esteemed Contributor
Hi John,
Can you post more of your code, particularly the require/function section?
JohnCartwright3
Thanks for your interest Ken, I've put it into a Gist
I think I have the "indexOf" issue solved - wait for all layers to be added to the map - but the CSS is still broken and it appears to want me to log in.  Wondering if this dijit only works w/ Portal-hosted services?
--john
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #map {
      height: 100%;
      margin: 0;
      padding: 0;
  </style>
  <script>
    var map;
    require([
      "dojo/on",
      "esri/config",
      "esri/map",
      "dojo/domReady!"
        zoom: 6
      var layers = [
          map: map,
  </script>
</head>
  <hr>
  <br>
</body>
</html>
JohnCartwright3
Thanks Robert, that was definitely an oversight on my part and your suggestion gets the dialog to display properly.
I'm now left with the question of why the dijit is requiring a login and not displaying the list of feature layers.  You don't have experience w/ this particular dijit do you?
Sorry can't say I do.
GaneshSubbiah
Hi John,
Analysis Dijits/Widgets work against ArcGIS SPatial Analysis Service, In the sample here you are pointing to a custom Extract Data GP Task which is not supported.
Working with Analysis Widgets | Guide | ArcGIS API for JavaScript 3.24
The Analysis Widgets provide access to the ArcGIS Spatial Analysis Service, which allows you to perform common spatial analyses on your hosted data, via the ArcGIS API for JavaScript.
Hope this helps
Thanks and Regards
Ganesh Subbiah
