External Library with TypeScript
1284
11-13-2020 09:56 AM
michael_vetter
I'm new to using TypeScript and had a question regarding how to use external libraries with the ArcGIS for JavaScript API. I'm trying to use the Chart.js library within my application, but I'm not sure how I would incorporate the library into the application. Is it as easy as using NPM to install the library?
Thanks for the help!
Michael
NicholasRomano1
Yes, it is as easy as using a npm package, but you'll need to adjust your project to use a package like esri-loader to load the API.
If you're not familiar with npm and build systems, you could just use the chart.js CDN and include it as a script tag.
