Extent of Polygons
1352
09-23-2013 01:05 PM
GianfrancoOliva
Regards,
I'm doing a query where I get polygons which are then drawn on the map. I need to know how I can set Extent to which can display all the polygons obtained from the query.
thanks
ZachLiu1
you can try this. It is written in AMD mode, so make sure you add "esri/graphicsUtils" in your require function parameters, and give it a local name "GraphicsUtils".
extGraphics = GraphicsUtils.graphicsExtent(resultFeatures);             map.setExtent(extGraphics);
ZachLiu1
GianfrancoOliva
very grateful!:D
