Extend Graphics class in Typescript using ES modules
2183
09-23-2021 09:54 AM
Alexandre-Notos
I want to create a new graphic type how ever the lastest https://developers.arcgis.com/javascript/latest/implementing-accessor/ instruction can't be follow because there is not ES module version.
Is there any guidance on how to proceed?
AndyGup
HI @Alexandre-Notos, the API functionality is exactly the same and for the TypeScript code you'll need to swap out AMD module paths with ES modules paths and turn the commonjs require statements into import statements.
AndyGup
Alexandre-Notos
@AndyGup Thanks for the info. I manage to find the right path.
Now in the following code is it possible to change the
properties?: any to
properties:
SegmentGraphicProperties
As the start point and end point are required?
import Graphic from "@arcgis/core/Graphic"; import { subclass, property } from "@arcgis/core/core/accessorSupport/decorators"; import GraphicsLayer from "@arcgis/core/layers/GraphicsLayer"; @subclass("esri.core.Graphic.SegmentGraphic") export class SegmentGraphic extends Graphic{     @property()     startPoint: GraphicsLayer;     @property()     endPoint: Graphic;     constructor(properties?: any) {         super(properties);         this.startPoint = properties.startPoint;         this.endPoint = properties.endPoint;     } }
