Export image from query
1593
10-25-2011 09:02 AM
spencermartin
Using rest api I need the bbox values from a query in order to export an image.  What is the easiest way from rest to query a field from a MapService and return the extent to then export that image?
HemingZhu
esri.graphicsExtent(featureSet.features).
spencermartin
Ok, that was helpful. Using the find feature I've retrieved the graphic and passed it to graphicsExtent.  Question I have now is how to make graphic extent zoom to extent of the found object.  This is without a map since I only want min max to create export image.
HemingZhu
extent =esri.graphicsExtent(featureSet.features).
var src ="http://yourMapService/export?bbox="+extent.xmin+","+extent.ymin+","+extent.xmax+","+extent.ymax+"&f=image"
spencermartin
Thanks for your quick and helpful solutions. Works perfectly.
