Experience Builder on Base Map Load Event
1216
09-20-2023 05:34 AM
Nadir_Hussain
Hello All,
I am trying to load my layers from arcgis server rest service URL.In my code i set the custom popup info for feature layer.this feature layer i want to load when first time experience builder load base map.I want to check Base map load.After this i want to add my feature layer on the webmap view.
jimuMapView.view.map.add(featureLayer);like this. in which file i have to add this function.
But how can i do this in experience builder without adding any user interaction and adding any new widget.
Please help.
Thanks
JeffreyThompson2
MVP Frequent Contributor
In the Experience Builder environment, it is impossible to add any code without creating a custom widget to put it in.
The most common and best way to add a featureLayer in Experience Builder is to create a webmap in your ArcGIS Online/Enterprise portal and then import that webmap using the Map Widget.
Here are some helpful tutorials if you are new to Experience Builder. https://learn.arcgis.com/en/paths/try-arcgis-experience-builder/
GIS Developer
City of Arlington, Texas
