Exclude sublayer from Legend
4558
05-24-2012 12:33 PM
ZahidChaudhry
Is it possible to exclude a sublayer from Legend (using Legend Dijit)?
derekswingley1
It's possible and was introduced at 3.0. We are missing info on specifically how to do this in the docs but we'll get it in there. Here's a modified version of our basic legend widget sample that shows this:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd">
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Map with legend</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.0/js/dojo/dijit/themes/claro/claro.css">
    <style>
      html, body { height: 98%; width: 98%; margin: 0; padding: 5px; }
      #rightPane{
        width:20%;
      #legendPane{
        border: solid #97DCF2 1px;
    </style>
    <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
    <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.0"></script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.layout.AccordionContainer");
      dojo.require("esri.map");
      dojo.require("esri.dijit.Legend");
      dojo.require("esri.layers.FeatureLayer");
      var map;
      function init() {
        var initialExtent = new esri.geometry.Extent({"xmin":-10753431,"ymin":4624151,"xmax":-10737799,"ymax":4635884,"spatialReference":{"wkid":102100}});
        map = new esri.Map("map", { extent: initialExtent});
        //Add the terrain service to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
        var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer");
        map.addLayer(basemap);
        var watershed = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/MapServer");
        var waterbodies = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/MapServer/0", {
          mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
          outFields: ["*"]
        //add the legend
        dojo.connect(map, "onLayersAddResult", function(results){
          console.log("results: ", results);
          var layerInfos = dojo.map(results, function(r) {
            var li = {
              defaultSymbol: false,
              layer: r.layer
            if ( r.layer.hasOwnProperty("name") ) { // feature layer
              li.title = r.layer.name;
            } else { // dynamic layer
              // hide the waterbodies layer as it's added as a feature layer
              li.hideLayers = [0];
            return li;
          var legendDijit = new esri.dijit.Legend({
            map: map,
            layerInfos: layerInfos
          },"legendDiv");
          legendDijit.startup();
        map.addLayers([waterbodies, watershed]);
        dojo.connect(map, 'onLoad', function(theMap) {
          //resize the map when the browser resizes
          dojo.connect(dijit.byId('map'), 'resize', map,map.resize);
      dojo.addOnLoad(init);
    </script>
  </head>
  <body class="claro">
    <div id="content" dojotype="dijit.layout.BorderContainer" design="headline" gutters="true" style="width: 100%; height: 100%; margin: 0;">
      <div id="rightPane" dojotype="dijit.layout.ContentPane" region="right">
        <div dojoType="dijit.layout.AccordionContainer">
          <div dojoType="dijit.layout.ContentPane" id="legendPane" title="Legend" selected="true" >
            <div id="legendDiv"></div>
          </div>
          <div dojoType="dijit.layout.ContentPane" title="Pane 2" >
            This pane could contain tools or additional content
          </div>
        </div>
      </div>
      <div id="map" dojotype="dijit.layout.ContentPane" region="center" style="overflow:hidden;">
      </div>
    </div>
  </body>
</html>
The key thing to note is on line 61. The layerInfo object for a layer has a new property defined called "hideLayers". This property is an array of integers. Each integer in the array corresponds to a layer index in a dynamic map service. If a layer's index is present in the hideLayers array, it is not shown in the legend.
AdrianMarsden
Honored Contributor
I'd like to know this as well?  Anyone?  Or shall we log it as as idea?
ACM
derekswingley1
<html>
  <head>
      on iOS devices-->
    <style>
      #rightPane{
        width:20%;
      #legendPane{
    </style>
      var map;
      function init() {
          outFields: ["*"]
        //add the legend
            var li = {
              layer: r.layer
            return li;
            map: map,
          },"legendDiv");
    </script>
  </head>
          </div>
          </div>
        </div>
      </div>
      </div>
    </div>
  </body>
</html>
RobertKirkwood
Ok, i have a backwards question:
How "DO" i include the sublayers in the legend?
here is my code bringing in the layer that has the sublayers:
-----Layer: ImprovementsAll (ID: 17)
Sub Layers:
ImprovementsStanding
ImprovementsNoStatus
ImprovementsConstruction
ImprovementsMaintained
ImprovementsPaved
ImprovementsPlanning
ImprovementsRemoved
ImprovementsSold
ImprovementsUnpaved
Display Field:
Type: Group Layer
//add the improvement data
                buildingsLayer = new FeatureLayer(getUrlKlondike("ImprovementsAll"), {
                    mode: FeatureLayer.MODE_ONDEMAND,
                    visible: true,
                    infoTemplate: template1,
                    outFields: ["*"]
                legendLayers.push({layer: buildingsLayer, title: 'Improvements:'});
when i add the buildingsLayer to:
map.addLayers([easementsLayer, easementsSelectLayer, disposalsLayer,buildingsLayer]};
it makes it so no layers are visible and the map hangs up. Any help would be greatly appreciated. Thanks!
AdrianMarsden
Honored Contributor
works a treat - many thanks
AdrianMarsden
Honored Contributor
Is it possible to also exclude the map service name?
ACM
Edit - OK - seen the title property in the reference.
