Example for CodedValueDomians
7854
8
04-29-2011 03:06 AM
MartinOver
Has anybody a working example how to deal with CodedValue Domains.
I have a Query Task on a layer with coded values and I want to show the names instead of the values in an InfoWindow. I could see the data via the rest interface:
e.g.: ... Domainn: Coded Value: [1:yes], [2:no]...
Best,
Martin
Mete_ErcanPakdil1
I'm also looking for an example for this, I hope someone have an example?
DonKang
Same here.
FindTask do return domain values but QueryTask doesn't.
Don
derekswingley1
The general workflow would be:
  • use esri.request() to get your layer's metadata
  • keep track of fields with domains
  • build an object for each field with a domain to map coded values to actual values
  • execute a query
  • when processing the query results, map the coded values from the attributes to actual values
Mete_ErcanPakdil1
  • execute a query
Thank you Derek, I will test this workflow and give an example here.
Btw, Is there any Esri's sample server which has coded value domain fields?
derekswingley1
Looking forward to see what you come up with. This service has several layers with coded value domains:  http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Energy/Geology/MapServer
JeffPace
We query each layer for the layer description.  We then pass the resulting featureset through a function to replace names with aliases, format numbers, and replace domains with their values
Function to do formatting/aliases/domains
org.mymanatee.common.util.getAliasDomainFormat=function(layerdesc, fieldName, field_val){
           dojo.forEach(layerdesc.fields, dojo.hitch(this, function(ldf){
                            if(ldf.name==fieldName){
                                //replace with aliases
                               fieldName = ldf.alias;
                             //  alert(ldf.name+" : "+ldf.type);
                              if(ldf.type=="esriFieldTypeDate"){
                               //    alert(ldf.type);
                               field_val=   dojo.date.locale.format(new Date(field_val), {datePattern: "MM/dd/yyyy"});
                             //  alert(field_val);
                              if(ldf.type=="esriFieldTypeDouble"){
                               //    alert(ldf.type);
                               field_val=   dojo.number.format(field_val,{places: 2 });
                              if(ldf.domain){
                                  dojo.forEach(ldf.domain.codedValues, dojo.hitch(this, function(domain){
                                      if(field_val==domain.code){
                                        field_val=domain.name;
                        return [fieldName,field_val];
function to get the layer description (by querying url with the ?f=json parameter) - ignore the replaces they are a cross-domain hack
org.mymanatee.common.util.getLayerDesc=function(url){
    var desc;
                                    var layerurl= ""+url.replace("http://home.intranet","")+"/?f=json";
                                layerurl= ""+layerurl.replace("http://www.mymanatee.org","");
                                var params = {
                 url: layerurl,
                 handleAs: "json",
                 sync: true
               var deferred =dojo.xhrGet(params);
                    desc= deferred.results[0];
    return desc;
Mete_ErcanPakdil1
Here is my sample code for who need to use.
dojo.require("esri.tasks.query");
function init() {
    var queryTask = new esri.tasks.QueryTask("http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Energy/Geology/MapServer/1");
    var query = new esri.tasks.Query();
    query.objectIds = [1];
    query.outFields = ["*"];
    queryTask.execute(query, function(featureSet) {
  var domains = [];
  var requestHandle = esri.request({
   url: "http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/Energy/Geology/FeatureServer/1",
   content: {f:"json"},
   callbackParamName:"callback",
   load: function(res){
    dojo.forEach(res.fields,function(f){
     if (f.domain != null)
      domains[f.name] = f.domain.codedValues;
    dojo.forEach(featureSet.features,function(f)
     for(attr in f.attributes)
      if (attr in domains)
       dojo.forEach(domains[attr],function(d)
        if (d.code == f.attributes[attr])
         f.attributes[attr] = d.name;
    console.log(featureSet.features);
   error: function(res){ console.log(res); }
  }, {useProxy:false});
      },function(err){
  console.log(err);
dojo.addOnLoad(init);
DavidHollema
For feature layers it's real simple.  The feature layer has a fields property and each field has a domain property.  As soon as the layer is initialized, the fields property is filled.  If you're dealing with ArcGISDynamicMapServiceLayers then follow the previously mentioned approaches.
See http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/codedvaluedomain.htm#codedValues
