esriRequest and outSR
2375
07-23-2019 05:09 PM
MinShin
I have feature service that has custom projection.
When I query features using this Query feature: https://gisportal.kisti.re.kr/server/rest/services/GBSK/인천시_행정동/MapServer/1/query
I can specify outSR to be {wkid:4326} and get the correct coordinates.
But when I try this using esriRequest, I don't see the same result. Sample is here. https://gbsk-kisti.s3.ap-northeast-2.amazonaws.com/EsriRequest.html
I have two questions.
1. how to get coordinates using esriRequest.
2. how to zoom/fit to a feature that has ring geometry.(source code line 104)
Thanks for your help in advance.
Regards,
Min
RobertScheitlin__GISP
Make this change:
        esriRequest("https://gisportal.kisti.re.kr/server/rest/services/GBSK/%EC%9D%B8%EC%B2%9C%EC%8B%9C_%ED%96%89%EC%A0%95%EB%8F%99/MapServer/1/query", {
          query: {
            where: "sig_kor_nm='연수구'", // honored
            outFields: "sig_kor_nm", // honored
            outSR: "{wkid:4326}", //honored
            f: "json"
          responseType: "json"
        }).then(function(response){‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
Min Shin,
   Here is your code working. I had to add all the proxy stuff so that I could hit your server from my webserver, you will most likely not need any of that.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8" />
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <title>Request data from a remote server - 4.12</title>
  <style>
    html,
    body,
    #container {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    .container {
      padding: 1em;
    #btnQuery {
      overflow: auto;
      text-align: center;
      cursor: pointer;
      font-size: 1em;
    input {
      width: 75%;
    #viewDiv {
      width: 500px;
      height: 500px;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.12/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.12/"></script>
  <script src="https://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js"></script>
</head>
<body>
  <div class="container esri-widget">
    <div>
      <h2>Using esri/request</h2>
      <button id="btnQuery">Make Request</button>
      <input id="inputUrl" type="text" value="//gisportal.kisti.re.kr/server/rest/services/GBSK/인천시_행정동/MapServer/1/query" />
    </div>
    <pre id="resultsDiv"></pre>
    <div id="viewDiv"></div>
    <div id="bookmarks"></div>
  </div>
  <script>
    require([
      "esri/request",
      "esri/Map",
      "esri/views/MapView",
      "esri/geometry/Polygon",
      "esri/config",
      "esri/core/urlUtils"
    ], function(
      esriRequest,
      Map,
      MapView,
      Polygon,
      esriConfig,
      urlUtils) {
      esriConfig.request.proxyUrl = "./proxy/proxy.ashx";
      esriConfig.request.trustedServers.push("https://gisportal.kisti.re.kr");
      urlUtils.addProxyRule({proxyUrl: "./proxy/proxy.ashx", urlPrefix: "https://gisportal.kisti.re.kr"});
      var map = new Map({
        basemap: "streets"
      var view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 12,
        center: [127.6, 37.5] // longitude, latitude
      var resultsDiv = document.getElementById("resultsDiv");
      var input = document.getElementById("inputUrl");
      $("#btnQuery").click(function() {
        esriRequest("https://gisportal.kisti.re.kr/server/rest/services/GBSK/%EC%9D%B8%EC%B2%9C%EC%8B%9C_%ED%96%89%EC%A0%95%EB%8F%99/MapServer/1/query?where=1%3D1&outFields=*&returnGeometry=true&outSR=%7Bwkid%3A4326%7D&f=json", {
          // 결과내 전체 피쳐
          response.data.features.forEach(feature => {
            // 행정구역명 확인. 읍면동은 emd_kor_nm
            console.log(feature['attributes']['sig_kor_nm'])
            // 버튼 생성
            var btn = document.createElement("button");
            btn.innerHTML = feature['attributes']['sig_kor_nm'];
            // 클릭하면 해당 구역으로 이동
            btn.addEventListener("click", function(e) {
              // 행정구역 폴리곤 생성
              const polygon = Polygon.fromJSON(feature.geometry);
              // 지도 이동
              view.goTo({
                geometry: polygon
            document.getElementById("bookmarks").appendChild(btn);
  </script>
</body>
</html>
MinShin
Hi Robert,
Thanks for your reply. My original intention was specifying the query options as object like below. Here, where and outFields are honored but not outSR. Original x,y values are returned and they are no good for moving maps.
If possible, I would like to use this format because of better readability.
query: {
outSR: {
wkid: 4326 // not honored
f: "json"
Regards,
Min
Make this change:
          query: {
            f: "json"
