ESRI watermark
4495
03-28-2014 10:15 AM
jaykapalczynski
Honored Contributor
Anyone know how to remove the ESRI water mark and replace with my logo of choice in the main MAP?
Thanks
JonathanUihlein
Jay, instead of making a new thread for every question you have, you should spend some time searching the forum or reading our API. You will find that more often than not, someone else has asked your question and received an answer.
      var map = new Map("mapDiv", {         basemap: "topo",         center: [-92.593, 38.5],         zoom: 7,         showAttribution:false,         logo:false       });
Hide Logo and Attribution:
http://forums.arcgis.com/threads/59229-To-remove-powered-by-esri-logo
http://forums.arcgis.com/threads/34111-HOW-TO-Remove-the-esri-logo
Replace Logo with Own:
http://forums.arcgis.com/threads/41800-Replace-ESRI-logo-with-custom-logo
Also, you may want to read this legal documentation to make sure you can freely remove the logo:
http://www.esri.com/legal/pdfs/mla_e204_e300/english.pdf
JonathanUihlein
jaykapalczynski
Honored Contributor
I can turn the logo off with "logo:false"
But in the bottom hand corner of the map I can still see "ESRI, DeLorme, FAO, USGS, NOAA, EPA, NPS"  anyway to get rid of that or is that a requirment when consuming the imagery from ArcGIS Online    "basemap: "topo"
KenBuja
MVP Esteemed Contributor
You forgot
as Jonathan had posted
jaykapalczynski
Honored Contributor
Kicked myself in the head...duhhh....
Thanks!!!!
