esri scalebar srcNodeRef
1557
02-15-2013 03:07 AM
NigelAlford
I'm unsure of how to use this property of the scalebar widget. If I pass the id with or without '#' as a string It does not attach to my div. Has anyone successfully used this, if so how?
var scalebar = new esri.dijit.Scalebar({                 map: map,                 srcNodeRef: "#scale",                 //attachTo: "bottom-right",                 scalebarUnit: "english"             });
NigelAlford
Resolved:
I just used Jquery to append the ESRI class to my desired div. With a small css overwrite this worked fine:
$('#scale').append($('.esriScalebar'));
NigelAlford
Resolved:
KellyHutchins
Esri Notable Contributor
Hi Nigel,
The source node ref needs to be specified after the parameters. Here's an example:
            map: map,
          }, dojo.byId("scalebar"));
