esri sample doesn't work
1059
08-07-2012 03:57 PM
HuiChen
I met an interesting issue while using "esri.dijit.editing.Editor" class that in esri javascript api 3.0. Essentially, after draw a polygon using "Polygon tool", the attribute inspector pops up. From then on, I can't select any other existing features. It works mostly ok, though,  when use "Freehand Polygon"  tool to draw a polygon. Except that drawing with "Freehand Polygon" tool stops panning activity. Same problem happens to one of esri editor sample:
http://help.arcgis.com/en/webapi/javascript/arcgis/demos/ed/ed_simpletoolbar.html
I have tried this sample both with IE 8 and Firefox and I got same issues as I described above.
Moreover, everything is all right when I revert esri javascript api to 2.8.
Has anyone seen the simliar issue before? Does "Editor" class has defects? Thanks for your help
Regards
Hui
Felipede_Morais
I solve this problem able and disable pan in map,
map.disablePan();
 //disable drag on map
 map.enablePan();
 //able drag on map
