ESRI Reference Error
1210
03-15-2013 07:13 AM
GlenReid
I have an older map application that is using version 2.8 of the API and it runs fine.  I updated the API and CSS references to version 3.3 and added the necessary ESRI CSS:
I now get the following 2 errors in FireBug:
ReferenceError: esri is not defined
var regionsGraphicsLayer = new esri.layers.GraphicsLayer();
gpAccumulation = new esri.tasks.Geoprocessor("http://gis.stage.ncdc.noaa.gov/arcgis/rest/services/gp/dailysnow2/GPServer/accumulation");
These errors are in external JS files (resis.js and dailyAccumulation.js).
Here is the JS code referencing those files in my JSP page:
 <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dijit/themes/claro/claro.css">
        <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dojox/grid/resources/Grid.css">
        <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/dojo/dojox/grid/resources/claroGrid.css">
 <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/js/esri/css/esri.css" />
 <link rel="stylesheet" type="text/css" href="css/snowfall.css">
    <script type="text/javascript">var djConfig = {parseOnLoad: true};</script>
 <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.3"></script>
  dojo.require("dijit.dijit");
  dojo.require("dijit.Dialog");
  dojo.require("dijit.form.Button");
  dojo.require("dijit.form.CheckBox");
  dojo.require("dijit.form.DateTextBox");
  dojo.require("dijit.form.TextBox");
  dojo.require("dijit.form.ValidationTextBox");
  dojo.require("dijit.layout.BorderContainer");
  dojo.require("dijit.layout.ContentPane");
  dojo.require("dijit.layout.TabContainer");
  dojo.require("dijit.TitlePane");
  dojo.require("dijit.Toolbar");
  dojo.require("dojo.data.ItemFileReadStore");
  dojo.require("dojo.fx");
  dojo.require("dojox.grid.DataGrid");
  dojo.require("esri.arcgis.utils");
  dojo.require("esri.dijit.BasemapGallery");
  dojo.require("esri.map");
  dojo.require("esri.tasks.gp");
  dojo.require("esri.tasks.locator");
  dojo.require("esri.tasks.query");
  dojo.require("esri.toolbars.navigation");
  dojo.require("esri.layers.graphics");
 </script>
 <script type="text/javascript" src="js/snowfall/init.js"></script>
 <script type="text/javascript" src="js/snowfall/locator.js"></script>
 <script type="text/javascript" src="js/snowfall/query.js"></script>
 <script type="text/javascript" src="js/snowfall/daily.js"></script>
 <script type="text/javascript" src="js/snowfall/dailyAccumulation.js"></script>
 <script type="text/javascript" src="js/snowfall/monthly.js"></script>
 <script type="text/javascript" src="js/snowfall/resis.js"></script>
 <script type="text/javascript" src="js/snowfall/dateValidation.js"></script>
Any ideas?
Glen
JohnGravois
please check out the "Referencing Objects and Properties in the esri Namespace" section of the article Migrating to 3.0.
this version of our API (and subsequent versions) have more strict requirements when it comes to code that references the esri namespace which are called before all modules loaded.
