esri is not defined
1944
8
01-16-2013 12:34 PM
EmilyLaMunyon
Hello,
When I try to upgrade my JSAPI web map to version 3.3 it stops working. In Firebug I get the following error:
esri is not defined on line 23 of http://serverapi.arcgisonline.com/jsapi/arcgis/3.3.
Did I miss a coding change that needs to happen from 3.2 to 3.3?
Thanks for any help.:)
PatrickTruitt
I'm getting the same thing. I can get it to work by clearing my cache and restarting the browser about a half a dozen times.
EmilyLaMunyon
Thanks Patrick.
This does not work for me, I am still getting the error. Is there something else it could be?
KellyHutchins
Esri Notable Contributor
Emily,
In the What's New at 3.3 help topic there is a small section that lists a few breaking changes.
http://help.arcgis.com/en/webapi/javascript/arcgis/jshelp/#whats_new
If that info doesn't help can you post a url to your site if you have a public link? Or perhaps some code?
Kelly
EmilyLaMunyon
Thanks Kelly!
Here is the url to my public test site. It loads fine when using 3.2, but the link I posted is set to 3.3 and it will not load.
http://www.surveyor.slco.org/ags10/javamappdf/select_right.html
KellyHutchins
Hi Emily,
I took a quick look and it looks like the url you provided is using 3.2. Can you re-post with the 3.3 version?
EmilyLaMunyon
Sorry about that, this should be set to 3.3.
Thanks!
MattLane
I checked out the link and it bombed on the first reference to the esri object in the GoogleMapsLayer.js file (line 11). Didn't investigate further, but that script is being processed before the 3.3 api. Not sure what changed in the new api, but the script load order seems to be the problem.
PatrickTruitt
If this helps, I had the same problem. I was using ClusterLayer.js via a dojo.require("extra.ClusterLayer"); Within this file, (ClusterLayer.js), there is a dojo.declare("extras.ClusterLayer", esri.layers.GraphicsLayer, { ....etc...}); What solved my issue was adding, to the top of this file, dojo.require("esri.layers.graphics"); reason being that this file was expanding GraphicsLayer without first added the the sub class first. Not sure why this worked on earlier versions though.
