esri is not defined inside JavaScript class
1070
03-11-2013 07:27 AM
YvanBérard
Hi guys,
i'm trying to build my web map with an javascript class, but it seems that the dojo.require("esri.map"); can't be called inside a class.
here is my javascript code:
dojo.require("dojo.fx");
 * Objet Mapper
var Mapper = function()
 // public variables
 this.map;
 // private variables
 // public functions
 this.init = init;
 this.initMap = initMap;
 this.buildDivs = buildDivs;
 function init()
  console.log("init");
        buildDivs();
     dojo.ready(initMap());
 function initMap()
  this.map = new esri.Map("map",{
            basemap:"topo",
            center:[-122.45,37.75], //long, lat
            zoom:13,
            sliderStyle:"small"
 function buildDivs()
  div_main = $('#main');
  div_map = $('<div id="map"></div>');
  div_main.append(div_map);
and inside my index.html I am calling the class when the document is ready:
<html>
 <head>
  <!-- TITRE -->
  <title>Cartographie 2.0</title>
  <!-- FORMATAGE -->
  <!-- DOCTYPE -->
  <!DOCTYPE html>
  <!-- XHTML -->
  <html xmlns="http://www.w3.org/1999/xhtml" lang="en" xml:lang="en">
  <!-- CSS -->
  <link rel="stylesheet" href="css/interface.css" type="text/css">
  <!-- JAVASCRIPT -->
  <script type="text/javascript" src="js/jquery-1.9.1.min.js" ></script>
  <script type="text/javascript" src="js/jquery-ui-1.10.1.custom.min.js" ></script>
  <script type="text/javascript" src="js/mapper.js" ></script>
  <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.3/"></script>
  <script type="text/javascript">
   var oMapper = new Mapper();
      $(document).ready(function()
       oMapper.init();
       console.dir(initMap());
  </script>
 </head>
 <body>
  <div id="main" class="container">
  </div>
 </body>
</html>
The error I get from FireBug is: ReferenceError: esri is not defined ( var tmp = new esri.Map("map",{ ...)
