ESRI direction service
1608
03-12-2019 05:26 AM
RatikantaLenka1
I am using arcgis javascript Direction Service.  After getting response the stops are not in order. That means the order I put the stops as input are different when I get the response from Direction Service.
JohnGrayson
Esri Alum
Try setting the findBestSequence to false parameter of your RouteParameters.
RatikantaLenka1
Thanks for your reply. Actually we are using Direction Serivce, and
there I can find no "findBestSequece" property.
https://developers.arcgis.com/javascript/3/jsapi/directions-amd.html#maxstopsreached
Thanks & Regards
Ratikant
JohnGrayson
Esri Alum
If using the Directions dijit in 3.17, I would start by looking at some of the constructor parameters such as 'optimalRoute' and 'showOptimalRouteOption'.
RatikantaLenka1
Thanks for your suggestion. I will try.
