esri.dijit.Bookmarks as Dojo ComboBox ?
1358
04-05-2018 12:03 PM
YvesMoisan
Hi All,
Examples of the Bookmarks widget I have seen so far are based on a Dojo button form widget (dijit.form.DropDownButton) rather than on a select form widget type like dijit.form.ComboBox.  Is the Bookmarks widget compatible with a Dojo ComboBox or FilteringSelect widget and if so are there examples around ?  I have tried a few things that all point to some sort of incompatibility with Dojo widgets other than the DropDownButton.  The reason I'd like a ComboBox is to get auto completion on the bookmarks array.
TIA,
Yves
RobertScheitlin__GISP
Yves,
   This question is a bit confusing. The Bookmarks dijit is a clickable list. You can display this list using a dropdown button as you mentioned. If you are wanting to filter the list then adding a textbox for filtering would look like this:
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8">
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Bookmark Widget (Editable)</title>
    <link rel="stylesheet" href="https://js.arcgis.com/3.23/esri/themes/calcite/dijit/calcite.css">
    <link rel="stylesheet" href="https://js.arcgis.com/3.23/esri/themes/calcite/esri/esri.css">
    <style>
      html, body, #map {
        height: 100%;
        margin: 0;
        padding: 0;
      .bookmark-container {
        position: absolute;
        top: 100px;
        left: 15px;
        padding: 1rem;
        background: #ffffff;
        border-radius: 4px;
        border: 1px solid #eeeeee;
    </style>
    <script src="https://js.arcgis.com/3.23/"></script>
    <script>
      var bookmarks;
      require([
          "esri/map",
          "esri/dijit/Bookmarks",
          "dojo/on",
          "dijit/registry",
          "dojo/parser",
          "dijit/form/TextBox",
          "dojo/domReady!"
        function (Map, Bookmarks, on, registry, parser){
          parser.parse();
          var map = new Map("map", {
            basemap: "topo",
            center: [-100, 40],
            zoom: 4
          // Create the bookmark widget
          // specify "editable" as true to enable editing
          bookmarks = new Bookmarks({
            map: map,
            bookmarks: [],
            editable: true
          }, "bookmarks");
          // Bookmark data objects
          var bookmarkJSON = {
            first: {
              "extent": {
                "xmin": -12975151.579395358,
                "ymin": 3993919.9969406975,
                "xmax": -12964144.647322308,
                "ymax": 4019507.292159126,
                "spatialReference": {
                  "wkid": 102100,
                  "latestWkid": 3857
              "name": "Palm Springs, CA"
            second: {
              "extent": {
                "xmin": -13052123.666878553,
                "ymin": 4024962.9850527253,
                "xmax": -13041116.734805504,
                "ymax": 4050550.280271154,
                  "wkid": 102100,
                  "latestWkid": 3857
              "name": "Redlands, California"
            third: {
              "extent": {
                "xmin": -13048836.874662295,
                "ymin": 3844839.127898948,
                "xmax": -13037829.942589246,
                "ymax": 3870426.4231173764,
                  "wkid": 102100,
                  "latestWkid": 3857
              "name": "San Diego, CA"
          // Add bookmarks to the widget
          Object.keys(bookmarkJSON).forEach(function (bookmark){
            bookmarks.addBookmark(bookmarkJSON[bookmark]);
          on(registry.byId("filter"), 'change', function(value){
              bookmarks.removeBookmark(bookmarkJSON[bookmark].name);
            var userVal = registry.byId("filter").get('value');
              if(bookmarkJSON[bookmark].name.toUpperCase().indexOf(userVal.toUpperCase())> -1){
    </script>
  </head>
  <body class="calcite">
    <div id="map"></div>
    <div class="bookmark-container">
      <input id="filter" data-dojo-type="dijit/form/TextBox"
        data-dojo-props="trim:true, intermediateChanges:true, placeholder:'Red'"
        style="width:100%;" />
      <div id="bookmarks"></div>
    </div>
  </body>
</html>
YvesMoisan
Thanx Robert.
Yves,
Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
