esri.digit.print
2244
08-23-2012 09:21 AM
p_thibault
I can not seem to get my print to recognise a template.
In the INIT function I have:
printer = new esri.dijit.Print({
map: map,
templates: template,
url: "http://gistest2:6080/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task"
},  dojo.byId("printButton"));
printer.startup();
This work well, except for the template.  I defined the template variable in the init function, before the printer as:
var template = new esri.tasks.PrintTemplate();
template: [{
label: "Map it",
format: "GIF",
layout: "A4 Portrait",
  exportOptions: {
  width: 200,
  height: 200,
  dpi: 96 }
I get a map, but none of the template formating is seen.
JianHuang
The correct syntax for assigning values to a variable is
var template =  [{
label: "Map it",
format: "GIF",
exportOptions: {
width: 200,
height: 200,
dpi: 96 }
p_thibault
Another way to ask the above question is... how does one get the Print digit to recognize a template?
template.exportOptions = {     width: 500,     height: 400,     dpi: 96   };
template.format = "PDF";
template.layout = "MAP_ONLY";
template.preserveScale = false;
"map": map,
"templates":template,
printer.startup();
}   //End of Init()
I do not get a pdf.  I get the default png. as an output, with default sizes.
JianHuang
the templates parameter in the print widget is an array of template.
p_thibault
In the first example(seen below), i believe that it is defined as an array..... the dijit still does not recognize it.
templates: [{     label: "Map",     format: "PDF",     layout: "MAP_ONLY",     exportOptions: {       width: 500,       height: 400,       dpi: 96     }   }, {     label: "Layout",     format: "PDF",     layout: "A4 Portrait",     layoutOptions: {       titleText: "My Print",       authorText: "esri",       copyrightText: "My Company",       scalebarUnit: "Miles",     }   }]
JianHuang
var template =  [{
label: "Map it",
format: "GIF",
exportOptions: {
width: 200,
height: 200,
dpi: 96 }
p_thibault
var template =  [{
label: "Map it",
format: "GIF",
exportOptions: {
width: 200,
height: 200,
dpi: 96 }
THANK YOU THANK YOU AND THANKS AGAIN!  A "=" instead of a ":" !!!  I starred at this for hours and read over the ":" a hundred times and never saw it.
