esri.config.defaults.map.slider in 3.3
1601
01-14-2013 01:13 PM
ScottSteigerwald
I just switched from 3.2 to 3.3 and it does not appear that the settings for esri.config.defaults.map.slider are being honored anymore?
I need the slider to be lower on the map and used esri.config.defaults.map.slider to set the top location. This was fine in 3.2, but in 3.3, it is not working.  Anyone else have this issue?
KellyHutchins
Esri Notable Contributor
The esri.config.defaults.map.slider options are no longer supported at version 3.3. Instead you can use the map constructor sliderPosition and sliderOrientation options:
      function init() {         var map = new esri.Map("map",{           basemap:"topo",           center:[-122.45,37.75], //long, lat           zoom:13,           sliderStyle:"small",           sliderOrientation:"horizontal",           sliderPosition: "bottom-left"         });       }
And here's a bit of css that could refine the top location:
      .esriLargeSlider{         top: 400px;       }
Link to api reference:
http://help.arcgis.com/en/webapi/javascript/arcgis/jsapi/#Map/MapConst
KellyHutchins
ScottSteigerwald
Thanks, that works! It's easy to miss things like this when they've been around for a while.
