esri.bundle strings 3.5 AMD
3891
11
07-25-2013 10:21 AM
CarlosMacias
it looks like the strings can't be set directly .
esri.bundle.toolbars.draw.addMultipoint = 'new text';
I tried redefining the property with code similar to this thread using this jsfiddle but didn't work.
how do we change the strings using 3.5 AMD?
CarlosMacias
it was because of my dojoConfig that I wasn't able to change the text.
I had it
var dojoConfig = {
        locale: "en",
        async: true,
        isDebug: true};
after commenting out the locale:"en" I can change the tooltip text.
DianaBenedict
multipoint uses bundle.toolbars.draw.addMultipoint (as you pointed out)
the following seems to work for me based on the fiddle:
          bundle.toolbars.draw.addMultipoint = "new text";
          alert("default add point text: " + bundle.toolbars.draw.addMultipoint);
CarlosMacias
Yes I am able to see it but when I change it, it doesn't appear as the tooltip when I'm drawing.
This is exactly what I want to do but in AMD.
CarlosMacias
changing the strings in the draw toolbar using 3.5 AMD.
does anyone has an answer for this thread?
EndreStokseth
Derek Swingley answered this in this thread with link to example on jsfiddle
JonathanUihlein
Endre, cmacias mentioned both that thread and the jsfiddle example in the first post of this thread, saying that he already tried to follow that example and it did not work.
Are you still having problems, cmacias?
CarlosMacias
Yes, I am still unable to redefine the tooltip text.
EndreStokseth
Sorry about a quick answer that gave nothing new to the thread..
But I have done this using AMD & JS-API v 3.5. It worked fine.
Added an example to jsfiddler (basically the same as Derek Swingley did).
Hope this helps 🙂
CarlosMacias
I had it
var dojoConfig = {
        locale: "en",
        async: true,
        isDebug: true};
CarlosMacias
try bundle.widgets.measurement.NLS_resultLabel instead of esri.bundle.widgets.measurement.NLS_resultLabel
